there is a screw that sits vertical in the front of the wheel well.
pull the inner guard back at the front and you should see where it goes
NB Bumper
- Regie
- Vehicle: NC - V8
Re: NB Bumper
- sliq
Re: NB Bumper
apart from that screw regie talks of, there's also a grey plastic clip that attaches the front bar to the chassis. it's located directly below the headlight. mine was busted until i had it replaced. it wriggled out a few cm's now and then when it was broken.
- Regie
- Vehicle: NC - V8
Re: NB Bumper
BarryB wrote:Thanks Sliq. Have had one go at it this morning and found a loose screw just behind the inner guard. Have tightened it up and all is well at this stage.
BarryB
sweet...too easy
and yeah i forgot about the clip that Mike suggested..could be the next step if the screw resecure fails
