Wet passenger feet
Old Dude
Re: Wet passenger feet
Postby Old Dude » Mon Nov 28, 2011 12:26 pm
If you put the top down at the top of the doors there is drains that run down to the bottom of the door, maybe those are blocked, also check the drain behind the seatbelt tower near the edge of the car.
cheers
Dale 8)
MX 5 2001 Grace Green
NB8B
JBT
Postby JBT » Mon Nov 28, 2011 3:52 pm
taminga16
Postby taminga16 » Mon Nov 28, 2011 4:18 pm
Hi Em,
Was there a result to this issue?
Greg.
Well that didn't go to where it was directed!
Postby 93_Clubman » Tue Nov 29, 2011 11:58 am
Also, on the NA8 at least, cabin air is drawn in from from a vent in the windscreen cowl immediately above passenger footwell. Vent has a plastic cover over it which channels water from bootom of windscreen/ back of bonnet. Leaves & other debris often collect under the plastic cover - worth removing cover & cleaning out under there if it looks like it needs it as the debris can trap water.
Postby Hammer » Wed Nov 30, 2011 8:50 am
+1 on the aircon drain hose. It's only secured together using friction and can be easily be kicked away and disconnected.
It's easily fixed by cable ties.
