NA Door Lock issue Can't open the door - Fixed
XB12R
Postby XB12R » Tue Nov 01, 2011 5:56 pm
Hey guys,
I know this is a common issue with the NA's, however I was only just new to learn about it.
Basically you can't open or unlock the affected door properly, turns out there is a little spring that fatigues and breaks.
MX5 Mania were able to supply a spring off the shelf for no hassle.
I wanted to share the link I found off another site that had easy to follow instructions took me 22mins in my lunch break to fix hardest part was getting the door trim off with he door closed.
http://www.mx5oc.co.uk/forum/forums/t/269.aspx
89 NA6
Is always hard to chose between the 5 and the Ducati
scud
Re: NA Door Lock issue Can't open the door - Fixed
Postby scud » Tue Dec 06, 2011 8:21 am
Just what i needed... sure beats jumping thru the passenger door
RED93
Postby RED93 » Tue Dec 06, 2011 3:17 pm
I want to see that Scud let me know and I will bring seats and spectators !!!
