Help needed with safety 21cage
red devil
Postby red devil » Sun Aug 21, 2011 8:47 pm
Just bought the cage and went to install it and cant figure out for the life of me how to install the two sections of cage that go through the parcel shelf :oops:
If anyone has had to go through this before the help would be really appreciated
Cheers Eren
I dont care that my laces aren't fat or that I'm not even close to flush and I certainly don't want to be the illest!
and1
Re: Help needed with safety 21cage
Postby and1 » Sun Aug 21, 2011 9:07 pm
Well with my NB MazdaSpeed cage you have to remove the metal panel that covers the front of the fuel tank. Then you have to line up the holes and drill through so you can bolt down to the chassis. Took me a while to realise how it bolted up too..
2005 Velocity Red MX-5 SE
Garage thread
red devil
Postby red devil » Sun Aug 21, 2011 9:10 pm
Did you have to tap the chasis? or did you just bolt into the hole you made?
thanks for the reply bud :lol:
and1
Postby and1 » Sun Aug 21, 2011 11:56 pm
Nope. Just drilled hole slide bolt through, place plate on from underside then put the nut on of course with washers inbetween. Not sure on a NA but on my NB there's a plastic trim piece in the wheel well that covers where the bolt pokes through
Garage thread
red devil
Postby red devil » Mon Aug 22, 2011 12:15 am
yeah i think the NA's a re a little different, when i removed the tank cover and put the bars on they sit directly on the chassis rails!
i'll have to troll the net n see how others have it me thinks
Cheers eren
Hjt
Postby Hjt » Mon Aug 22, 2011 12:26 am
Hey mate ask Charlie_91 as he has a similar cusco cage, also search the clubroadster.net forums
red devil
Postby red devil » Mon Aug 22, 2011 6:24 pm
Ok so charlie gave me all the info I need to install the cage (big thank you there) and to HJT for putting me in the right direction! Iv also found that im missing some backing plates so i'll have to make them up before i can install the rear section
Eren
-alex
Postby -alex » Mon Aug 22, 2011 6:40 pm
Hope its done by Wednesday!!
Can't wait to see this thing.
Sasso - 06/05/10 ♥
