What is this broken wire in my soft top NB Series 2
CoachOz
Postby CoachOz » Sat Aug 20, 2011 7:27 pm
Today I was poking around trying to find a rattle in the roof. I didn't find the rattle but I noticed on each side towards the rear a small spring with a thin wire attached to it leading into the soft top. Does anyone know what this is?
2020 ND 2 GT
2000 NB Heritage
[imgImageHeritage 2 by Peter Rodgers, on Flickr[/img]
Mr_Q
Re: What is this broken wire in my soft top NB Series 2
Postby Mr_Q » Sat Aug 20, 2011 9:00 pm
Mister Q
CoachOz
Postby CoachOz » Sat Aug 20, 2011 9:09 pm
Nope, smaller spring, thinner and flexible wire about 30 cms before the break. Looks like it should go all the way around as similar wire on driver's side is loose
2020 ND 2 GT
2000 NB Heritage
CoachOz
Postby CoachOz » Sat Aug 20, 2011 9:50 pm
Ok I've identified it as the tension cable - but how do I replace it?
2020 ND 2 GT
2000 NB Heritage
Postby manga_blue » Sat Aug 20, 2011 10:02 pm
Buying it is the first step. UK's MX5Parts is the default global supplier and they're very, very good at it.
http://www.mx5parts.co.uk/product_info. ... cts_id/451
As for everything else, the fitting instructions are on miata.net, as in http://www.google.com.au/#sclient=psy&h ... 20&bih=965
CoachOz
Postby CoachOz » Sat Aug 20, 2011 11:00 pm
Thanks for all your help. I've ordered the part from the UK at half the price (including postage) compared to MX5 Mania and downloaded the instructions. Will need to put aside a few hours to install the cable.
2020 ND 2 GT
2000 NB Heritage
