So I just picked up a 1.5 DIN cubby hole from Mazda and the part number is FC02-55-235A. From my Googling before I could have sworn it's the right part. But when I went to put it in, it doesn't fit. It's like 0.8 cm too thick and clashes with my Pioneer 1 DIN Head Unit. And instead of being a rectangular box seen in the pictures, there's actually a slope on the top face and converges towards the back.
Should I have bought a 1 DIN cubby hole instead? But that wouldn't make sense because I remember reading the OEM tombstone for the '90 NA was 2.5 DIN in total, yes?
Is this when I should have bought the 'updated' tombstone from Mazda as well? Or do they also sell a tombstone+cubby bundle that leaves a 1 DIN head unit spacing?
[NA] 1.5 DIN Cubby Fitment Issue
Momo (aka 1990 white NA6)
- ak_perth
Re: [NA] 1.5 DIN Cubby Fitment Issue
I have just fitted a 1 din head unit to my 94 Clubman. I bought a radio cubby box from MX5 Parts in England to fill the gap that the 1 din head unit creates.
The cubby box is a perfect fit with the new 1 din head unit and even the black plastic finish matches the tombstone.
http://www.mx5parts.co.uk/product_info. ... cts_id/119
AK
AK
Yeah, I know about this part. Is this obtainable from the Mazda dealers locally or only from mx5parts? And this will fit directly onto my OEM tombstone from 1990?
- ak_perth
I think it's only available through MX5 parts.
It fitted perfectly to my 94 NA Clubman. I'm pretty sure the tombstones for all NA's are the same. You could give them a call and ask?
I lot of people have upgraded their tombstones over the years, perhaps yours has already been upgraded.
Well, that is a possibility. The leftover cover plate is around the size of the head unit and there's only a small gap (around 1cm) between them..
- Vehicle: NA6 - Turbo
i just cut down one from a ford telstar. i think they are originally 2 din and i just trimmed the top of the cubby t fi in the gap....
Opps, I forgot to mention, I got a 1DIN from the dealer as a replacement and then just put it in. There's a small gap at the top and the bottom, but not very visible unless you look hard.
