Boss kit / hub adapter for NB?
timk
Postby timk » Tue Apr 12, 2011 12:25 pm
Hi,
Does anyone know of a boss kit to suit the spline on the NB? It's for an OMP wheel which I think has 6 bolts with 70mm spacing between opposite holes.
There's plenty around that say they will fit the NA up to '97, but I have no idea if the NA and NB share the same spline.
I've attached a pic of the spline measurement but I'm not even sure if this is the correct way to measure it! :oops:
Re: Boss kit / hub adapter for NB?
Postby 93_Clubman » Tue Apr 12, 2011 1:22 pm
saboteur wrote:There's plenty around that say they will fit the NA up to '97, but I have no idea if the NA and NB share the same spline.
According to Miata.net Garage Compatibility it seems there are fitment problems - see last entry under aftermarket: http://www.miata.net/garage/compatibility.html
NMX516
Postby NMX516 » Tue Apr 12, 2011 8:30 pm
Ask mazlot, he had a Sparco I think it was in his SP.
elitee
Postby elitee » Tue Apr 12, 2011 9:54 pm
I jUst picked up a omp + qr short hub and D1 spec qr
Haven't had a chance to out it on as of yet
timk
Postby timk » Thu May 05, 2011 4:49 pm
Just for people doing a search later on; the spline is the same so the boss kit will work, but you may need to crack out the Dremel to make some allowances for the clockspring.
Boyracer
MX-5 Encyclopedia
Postby Boyracer » Wed May 11, 2011 8:17 am
Normal NA mx5 hub fits on NB just get rid of the clock spring on a race car.
Users browsing this forum: No registered users and 240 guests
