I'm wanting to remove my Nardi wooden handbrake handle from the handbrake stalk, anyone know how you get one of these off?
I bought this one as the entire unit it appears so its never been off the stalk since i owned it, doesn't seem to have the small gap at the bottom of it that the original plastic one has which you get that off with.
Removing Wooden Nardi Handrake Handle
- ForceMajeure
- de Bounce
Re: Removing Wooden Nardi Handrake Handle
I have pulled a couple of stock handbrakes apart.
The grip is slid onto a smooth tube and glued.
Try heating the grip to soften the glue and giving it a good twist as recommended HERE.
If you don't want to risk damaging the grip, consider getting another 2nd hand handbrake and changing out the whole item.
- ForceMajeure
Well i ended up sliding it off after wiggling it a lot.
Its a very delicate operation getting it back on though, very easy to crack the wood IMO.
