Ok, just found and fitted a secondhand (fairly period) Nardi flat bottomed steering wheel. Looks and feels great.
Thing is, I cannot get the splines to make the flat horizontal when the wheels are straight ahead.
1. anyone able to help my OCD (now offically CDO - because THEN the letters are in the right order)
2. are the any other areas I can adjust in the steering column??
OldCootDriver
Flat-bottomed Steering Wheel: alignment
- Learner Driver
- Vehicle: NA6 - Supercharged
- de Bounce
Re: Flat-bottomed Steering Wheel: alignment
Need to adjust the tie rods
Wheel alignment shop can do it
- Bauer
wouldnt be a Nardi wheel on a momo boss would it?
Havent I read somewhere that the bolt pattern is the same but its half a spline out, thereby not aligning the wheel???
Been known to be wrong before, I just remember reading that somewhere.
cheers
Stu
Stu
- Steampunk
oldcoot wrote:1. anyone able to help my OCD (now offically CDO - because THEN the letters are in the right order)
hahaha!
Just sit on some padding under one butt-cheek so you lean the same way as the wheel so it makes it look level
- Uncle Arthur
- Dodgy Award Benefactor
- Location: Doesn't matter where I'm from-it's that your daughter is with me that's the biggest concern :D
Same thing can happen with any new steering wheel - or old one.
Get an alignment done - they should ensure the (steering) wheel is straight, THEN align the wheels. Bob Jane Taringa, or Fulcrum at Rocklea are both well equipped and experienced to set up the 5 properly.
- Learner Driver
1red5, I like your style & Unkle Arthur; your information.
- Guran
- Vehicle: ND - 1.5
It's an easy DIY job if you're so inclined. All you need is a string line, a ruler and a couple spanners for the tie rods.
The old wheel aligners trick is to adjust each tie rod end the same amount in the same direction. thus lenghening one adjuster and shortening the other by the same amount. In therory you wont adjust the total toe of the vehicle and hey prestoe if you do it in the right direction the steering wheel get centred.... or even worse in which case repeat the same operation in the opposite direction only twice as far.
Best solution it to get a 4 wheel thrust alignment. And most specialist suspension shops will know what you want. Ie get the total toe and camber speced on the rear before adjusting the front camber/caster setting and in the final castor swing set the steering wheel centre.
now all this said if you have crap old tyres on your car fitted by the local garage give up. try the first method until you can afford good tyres that have been correctly fitted..... Thats another post.
all this said I am a Wheel aligner by "trade"... but lying under hot oily cars is not my idea of a dream job...
Apart from Mazda............ trust nothing else...
Users browsing this forum: No registered users and 238 guests
