What i did on my holidays - or its red again !!
Posted: Sun Jan 30, 2011 5:00 pm
I bought my little Na6 a few years ago with pretty tired paint (well, it was pink on most panels !)
Some nasty fruitbat had deposited a lump on the bonnet and on removing it, a large hole appeared in the paint !! - seems that bad guano rots body filler, who knew ?
The front bar was cracked and nasty looking with peeling clearcoat and basically ugly.
so over xmas i decided to give it a little spruce up...
1 litre of Classic Red was mixed by my friends at Auto-Pro west gosford, and some fibreglass matting was acquired from Glenn at rebel Spares (White Monaro, very nice..)
I'll let the pics tell the rest.
First thing i did was remove the front bar and scuff the paint with 400 wet / dry and plenty of water
The front bar was re-glassed and filled (this is a middle-stage photo, sorry, forgot to take pics at each stage !)
I gave the whole body a rub down with wax and grease remover (Super-cheap auto) and layed 3 light coats of paint (1:1.5 / paint:thinner)
A few more coats and it was starting to look better
, so i took it outside to harden for a few days (2 weeks it turned out to be thanks to a failed ISCV sensor.. bleurgh)
A little bit of polishing later (try close to 12 hours !!) (large orbital polisher - first time I've ever used one, not too bad if you get your speeds right!)
I suppose the take home story is that an uneducated fool like myself can spray panels, its not perfect, but then again this is my every-day car, and I'm not a spray-painter!
I like how it came out, but ifi was to do it again, I'd use a LOT more paint (about 3 liters i think) and get someone else to polish it !!
