NA8 Mirrors = Can they be resprayed
Re: NA8 Mirrors = Can they be resprayed
Postby Hammer » Thu Nov 18, 2010 3:43 pm
Yes, they can be resprayed with any colour you like.
As for How and Repairs, I'll leave that to the expert to answer.
baldas
Postby baldas » Thu Nov 18, 2010 8:34 pm
Question = Can NA8 mirrors be resprayed? - as mentioned above - yes. If they are scratched down to the plastic be careful in your preparation - some plactic primers don't adhere well to the oem paint.
How = What is the procedure? - Sand surface, prime, sand, base coat then clear - youtube is your friend here - lots of how to videos re painting cars
Colour = Is it possible to change the colour? - must be tasteful - you will look at it a lot while driving
Repair = Can the mirrors be taken apart and if so, how is this achieved? - To take the mirror apart you first have to remove the glass - this is the hardest part. There is a lip all the way around and some sticky white stuff in the middle. Don't rush it, don't use metal tools (I used plastic strips to level the glass off). Behind the glass is one screw in the centre - remove this and the plastic mirror surround comes off. You can then remove the motor unit. Pulling it apart further is something I have not attempted - but I didn't think it necessay in my case. In fact the second mirror I just masked up the mirror rather than remove it.
aviper4u
Postby aviper4u » Sat Nov 20, 2010 4:41 pm
just dont forget if your painting bare plastic i believe you need a speciel plastic primer.
good luck and tell us how you go
Postby 93_Clubman » Thu Dec 23, 2010 5:32 pm
mazdatenfive wrote:Managed to remove glass using a heat gun. Now all is revealed.
they sound like the sealed na6 ones
Postby 93_Clubman » Thu Dec 23, 2010 11:45 pm
oh no - na8 power mirrors
Bunnings etc?
Adam_NAclubman
Postby Adam_NAclubman » Wed Dec 29, 2010 5:32 pm
I sprayed a red NA8 mirror white, but I can't remember if we just sanded it then sprayed, or primed it after sanding. Either way, its still nice and white a couple of years later and probably has the best finish of any painted surface on the car
