Fitting a hardtop in Adelaide
Elmo
Postby Elmo » Thu Aug 12, 2010 7:22 pm
Hi, Does anyone in SA know where I can take my hardtop to have the fittings/brackets checked out. I think my hardtop is a little loose and seems to have a dodgy fitting on the rear right hand side :shock:
Cheers :wink:
zephyrus17
Re: Fitting a hardtop in Adelaide
Postby zephyrus17 » Mon Aug 16, 2010 11:43 pm
You could try Southern Hitech Dyno Tune around Melrose Park. They're quite experienced with MX5s. Give them a ring and check.
Momo (aka 1990 white NA6)
SuperMazdaKart
Postby SuperMazdaKart » Mon Aug 16, 2010 11:52 pm
They were the ones who did an NB6 engine swap into my NA6.
Elmo
Postby Elmo » Tue Aug 17, 2010 7:31 pm
Thanks for that, I've got a bolt that's come loose but I can't seem to find a nut that will fit the bolt and also fit into the space on the chrome hardtop bracket???
Do you know where to get the felt/rubber sleeves I think there called that fit to the bottom of the chrome hardtop brackets
I was told my hardtop is missing these bits :shock: and its causing the chrome metal brackets to rub on the metal plates where the frankenstein bolts are :evil:
