Removing spare wheel mount
davekmoore
Postby davekmoore » Sat Jul 24, 2010 11:14 am
To make more space in the boot I've removed all the trim and the spare wheel and have invested in two cans of puncture repair stuff. Fingers crossed eh?
For further space, what's the best way of removing the mounting that the spare wheel fixes to in the boot? And the jack mounting?
Fatty
Re: Removing spare wheel mount
Postby Fatty » Sat Jul 24, 2010 11:19 am
use an angle grinder
Postby fastfreddygassit » Sat Jul 24, 2010 10:29 pm
Fatty wrote:use an angle grinder
X2
use the 1.0mm cutting discs.
davekmoore
Postby davekmoore » Sat Jul 24, 2010 10:54 pm
Thanks for the advice. I'll be entrusting this to someone already owns an angle grinder and who hopefully won't a) die or b) remove the whole boot.
Postby Mr Morlock » Sun Jul 25, 2010 1:07 pm
MX5s never were and never will be goods carrying vehicles. Sounds like you need something more suitable. Nice sense of humour by the guys- tackle the problem with an angle grinder.
RG.net
Postby RG.net » Sun Jul 25, 2010 1:09 pm
Drill the rivets out.
MINX
Postby MINX » Sun Jul 25, 2010 4:06 pm
If you remove the fuel tank, that would free up heaps of space.
davekmoore
Postby davekmoore » Sun Jul 25, 2010 9:57 pm
MINX wrote:If you remove the fuel tank, that would free up heaps of space.
... leaving more room to fit the towbar to pull the trailer; no, better idea - caravan.
davekmoore
Postby davekmoore » Sun Jul 25, 2010 10:01 pm
........... but seriously, I sell stuff for a living. If I was any good as a handyman I wouldn't ask these stoopid questions. To give you an idea of how bad I am, I seriously congratulated myself when I managed to change the ride height on the car (this became easier when I got the correct spanners by the way).
So is an angle grinder the go? Or if drilling the rivets out is the better answer, how do I refill the holes?
Fatty
Postby Fatty » Sun Jul 25, 2010 10:19 pm
if it's riveted on then drill the rivets. you may be able to refit it later if you do this, too. i just assumed it was spot welded in which case the angle grinder will do the job.
GP
Postby GP » Mon Jul 26, 2010 1:12 pm
Get some repair ropes as well, The cans will only work on some holes.
Graham
Postby Okibi » Tue Jul 27, 2010 1:44 am
I always wished they'd put a canon style muffler on the left hand side and made the boot much deeper, might do that mod one day.
davekmoore
Postby davekmoore » Sun Aug 01, 2010 9:24 pm
Now there's a thread about relocating the spare to under the car.
Bet it won't work with the extra braces under an SE though??
Users browsing this forum: No registered users and 60 guests
