Have you seen this rollbar?
Nocturnal
Postby Nocturnal » Thu Jul 15, 2010 1:31 pm
Does anybody recognise this rollbar?
Supposed to be for an NA, cannot figure out how to mount it.
Halp plz.
StanTheMan
Re: Have you seen this rollbar?
Postby StanTheMan » Thu Jul 15, 2010 1:36 pm
looks like a mazspeed one or the other brand whose name escapes me.
part of it goes on the parcel shelf. The other behind the seats on the floor.
Postby bruce » Thu Jul 15, 2010 1:42 pm
Plenty of discussion regards this rollbar. So much, even I know how to mount it. The back arms have to go through the parcel shelf (cut some holes or remove panels).
It is logical. You make it fit.
Nocturnal
Postby Nocturnal » Thu Jul 15, 2010 1:46 pm
bruce wrote:Plenty of discussion regards this rollbar. So much, even I know how to mount it. The back arms have to go through the parcel shelf (cut some holes or remove panels).
Sorreh, links?
BadBong
Postby BadBong » Thu Jul 15, 2010 1:55 pm
This looks like an item that was listed on eBay a little while ago?...
I recall the description saying that it's not a standard/popular boll bar and will need you to drill holes into uncommon places...
Nocturnal
Postby Nocturnal » Thu Jul 15, 2010 2:08 pm
Yeah I didn't pull it off ebay. Found this thread: viewtopic.php?f=28&t=38881&p=516425&hilit=mazdaspeed+rollbar+install#p516425
But it isn't the same bar. Have the panels on the parcel shelf out, sits flat on the floor but the rear diagonals still float.
Nocturnal
Postby Nocturnal » Thu Jul 15, 2010 2:23 pm
There are plates on the bottom on the rear diagonals, but to think that you mount those plates on the deck and suspend the rollbar but long bolts is surely madness, yes?
geofiz
Postby geofiz » Tue Jul 20, 2010 11:01 pm
If you are still having trouble with this, let me know and I can probably help. I have the same cage in a 6 point version in the shed, and can take a few photos in various stages of assembly if required.
NB8A - mostly stock for now
