NC passenger carpet severe water logging
Posted: Wed Mar 31, 2010 11:31 am
by Benny
If the car is still under warranty, take it back to the dealer and get them to fix it AND replace the carpet.
If not, well, someone with more experience on the NC should be able to help you.
Posted: Wed Mar 31, 2010 12:31 pm
by bruce
Pop out the rubber bung in the passenger footwell (it will let all the water out at least).
Posted: Wed Mar 31, 2010 8:23 pm
by de Bounce
I'm guessing you have a soft top, if so check the drain holes which are located behind the seat belt top mounts. They could be blocked causing the flooding.
Last time this was discussed, I think someone mentioned a recall affecting the NC's.
There is some info
HERE and
HERE although the discussion was NA/NB specific, some of the principles apply to the NC.
This one is for the NC
HERE
Posted: Thu Apr 01, 2010 9:24 am
by MR5000
Guys, I've owned my NC for about 2 months now without seeing rain, untill now and yes the passender side carpet is wet
not soaked but a little damp and the car is starting to smell damp.
Without taking it to the dealer is there instructions somewhere on how to flush these drains out as it's about 2 months out of warrenty.
Abit upset about splashing up a sh*t load of money and to have problems already
Not happy.
Paul
Posted: Thu Apr 01, 2010 10:44 am
by Mr Morlock
the dealer is sure to give you advice on what to do-- go and have a chat unless a forumite has nailed it.
Posted: Thu Apr 01, 2010 1:19 pm
by MR5000
Doing alot of searching and it apears to be a problem with the NC's
Found a Mazda Service Bulletin, looks like a big job.
http://www.finishlineperformance.com/pd ... -2104c.pdf
