Legal Roll Bar - Victoria Specific
de Bounce
Postby de Bounce » Sat Mar 27, 2010 9:34 am
Looking to purchase a roll bar for my NB
One of my requirements is to keep the car road legal.
Having read most discussions about roll bars on the forum, a number stating that they must be engineered for use in Victoria.
I found the VicRoads Vehicles Standard Information #28 covering Roll Bars and Roll Cages.
Under the heading 'Introduction' it states
Regulation 819 of the Road Safety (Vehicles) Regulations 1999 requires that all modifications to a vehicle either have specific approval from VicRoads or be carried out in accordance with guidelines published by VicRoads.
Installing a roll bar or roll cage in a vehicle is a modification.
For the purposes of Regulation 819, this document is a guideline published by VicRoads and consequently, any roll bar or roll cage made and installed in accordance with this document is an approved modification.
From this I understand that if the bar follows the rules of this Vehicles Standard Information sheet, it is an approved modification.
The next clause/concern is half way down the second page.
NOTE: Seat belt and seat anchorages installed as original equipment by the vehicle manufacturer must not be used for attaching roll bars or cages or any other fittings.
Of the two types of Australian manufactured roll bars we have the Brown Davis bar Image
(Image Credit to Kula's NA6 build thread)
Clearly shows the seat belt top mount bolt used to secure the bar which would mean it is not in accordance with the Vehicles Standard Information sheet and therefore requiring an Engineers Report.
Second type is from MX5 Plus (Forum Sponsor) (Image from their web site)
This one uses a separate top mount.
Without going into the 'this is better that that', my question is.
Does the MX5 Plus bar comply with this clause in the Vehicles Standard Information sheet therefore being deemed an approved modification.
Thanks
Motorkhana Video
Postby bruce » Sat Mar 27, 2010 10:35 am
Whatever any of us say, it will only be our opinions (and then maybe not Vic specific).
I would ring BD and MX5plus and ask them directly. They can point you in the direction of an engineer if you then require a certificate. Problem is, a cert will probably be over $500 alone.
mx52nv
Purple Porsche Eater
Postby mx52nv » Sat Mar 27, 2010 11:01 am
If VicRoads are the authority on the subject, then you should print the photos out and bring it to them for confirmation. If approved, get it in writing (permit?). Both insurance and the police will be satisfied if they have queries.
Les
Old Dude
Postby Old Dude » Sat Mar 27, 2010 11:18 am
I know that both the guys at MX 5plus are engineers and don't like the seat belt mount to be used to mount the rollbars, hence thats why theirs is different.
As to whether it complies with Victorian requirements you would have to check with Vic Roads.
I have one of their bars, and are very happy with it, I also had to get an engineers certificate for QLD RTA, which they supplied after inspecting the installation, so there was no drama's there either way. But that was in QLD
Good luck with the research
Dale 8)
MX 5 2001 Grace Green
NB8B
Postby orx626 » Mon Mar 29, 2010 4:00 pm
de Bounce wrote:From this I understand that if the bar follows the rules of this Vehicles Standard Information sheet, it is an approved modification.
Thanks
Yes, the MX-5 Plus Torque Box roll bars comply with this clause. This detail was a key part of the functional design.
Regards,
Dweezle
Postby Dweezle » Mon Mar 29, 2010 4:35 pm
Not to Thread Steal or anything :oops:
Is the TB bar now CAMS approved??
ALL MUSCLE CARS ARE CRAP
Jeremy Clarkson
Postby orx626 » Mon Mar 29, 2010 4:50 pm
Dweezle wrote:Not to Thread Steal or anything :oops:
Yes Dweezle there is a version of the TB single hoop that has a single diagonal which meets the prescriptive requirements of the CAMS manual and is therefore eligible for CAMS approval. I believe "rain902" has already been through the exercise. For more information regarding the single diagonal TB roll bar send an e-mail to parts@mx5plus.com.au.
de Bounce
Postby de Bounce » Mon Mar 29, 2010 7:11 pm
Thanks for the clarification orx626.
Makes a fair bit of difference in the total cost of a 'Legal" bar in Victoria as you would avoid the engineering requirement for the Brown Davis bar.
Motorkhana Video
land864
Postby land864 » Wed Mar 31, 2010 12:19 am
Hi DB , so is the MX5 Plus twin hoop torque bar okay for club track days etc
StanTheMan
Postby StanTheMan » Wed Mar 31, 2010 1:04 pm
very good info here although only Victoria specific I feel the info is fantastic. I wonder if Okibi could make this a sticky or if we can put this info where its easyly found?
Postby orx626 » Wed Mar 31, 2010 1:33 pm
StanTheMan wrote:very good info here although only Victoria specific I feel the info is fantastic.
Hi Stan, without having investigated each of the states policies on roll cages/roll bars, I wouldn't be surprised if this particular clause exists across the board.
This clause certainly exists in the NCOP (National Code of Practice for Light Vehicle Modification) which was developed to have a standard set of prescriptive and performance requirements for light vehicle modification no matter what state/territory you reside. To my knowledge not all states have adopted the NCOP in full, because if they did, there would be no need for their respective state divisions! :? So I don't think that we will ever have a standard set of rules Australia wide. :x
de Bounce
Postby de Bounce » Wed Mar 31, 2010 7:36 pm
land864 wrote:So is the MX5 Plus twin hoop torque bar okay for club track days etc
I'm more than happy for anyone who knows the correct answer to jump in on this.
I have asked a couple of people (who should know) if a NON CAMS Approved Bar, fitted to a road registered vehicle can be used at a CAMS speed event.
So far I have received a couple of conflicting answers and no one could provide a reference.
Motorkhana Video
Postby orx626 » Wed Mar 31, 2010 7:50 pm
With regards to club track days (eg. MX5 Club of Queensland).....you can run without a roll bar anyway...AASA do not demand that one be fitted. With regards to CAMS sanctioned events where the vehicle you are racing must have a CAMS log book, you will not be able to run with a non-CAMS homologated roll bar or roll cage.
Regards,
greenMachine
Postby greenMachine » Wed Mar 31, 2010 9:22 pm
Regards,
I think you mean " you will not be able to run without a non-CAMS homologated roll bar or roll cage"
:mrgreen:
Postby orx626 » Thu Apr 01, 2010 6:22 am
greenMachine wrote:I think you mean " you will not be able to run without a non-CAMS homologated roll bar or roll cage"
:mrgreen:
Not sure I get what you mean....if you have a CAMS log booked car, the roll bar / roll cage must also be CAMS approved.
