Early NA rearview mirror fit in late NA?
brenno
Postby brenno » Sun Jan 17, 2010 12:48 pm
My '97 NA8 has one of the mirrors that glue on to the windshield. I've tried all sorts of glues and procedures but it keeps falling off.
I've noticed that the early NA mirrors attach on to the top of the windshield, possibly using the interior light as a mount.
Is there any problem in finding the earlier type mirrors and retrofitting it to an NA8?
Cheers...
White NA8
green_comet
Car Detailing Guru
Postby green_comet » Sun Jan 17, 2010 2:51 pm
Go see a windscreen place, and ask them to stick it back on for you. They have the proper glue, and it shouldnt cost much.
I dont think you could use the early mirror, as there is no mount under the light. You could probably mod it to fit, but its not worth it. Go get a shop to stick your one back on.
Bauer
Postby Bauer » Sun Jan 17, 2010 5:51 pm
brenno wrote:My '97 NA8 has one of the mirrors that glue on to the windshield. I've tried all sorts of glues and procedures but it keeps falling off.
I have refitted quite a few in my time with great success (though my 'time' fixing cars was last century) and the key was to do it by the book. Buy the right glue - Repco, autObarn etc sell a rear view mirror adhesive [permatex brand from memory] and follow the instructions to the letter (with 1 exception).
You need to have the both surfaces clean as clean as clean so dont forget to mark the outside of the windscreen with a whiteboard marker so you know where it goes. It should be so clean that you would have no idea where it goes otherwise.
When you glue the silver bit on to the glass, it goes without saying that the mirror shouldnt be attached. Stick it on and tape it in to position. If the instructions say to leave the silver bit glued on for 2 hours before refitting the mirror, leave it 24. If it says 24, make it 48 (the exception to following the instructions.)
Hope that helps. Its a bit like the carpenters rule of measure twice, cut once. This time is do it properly, do it once.
Stu
cheers
Stu
brenno
Postby brenno » Tue Jan 26, 2010 3:00 pm
Thanks, that was the answer I was looking for.
White NA8
