NB BD Bar installation on NA
Posted: Sat Nov 21, 2009 12:38 pm
Hi guys,
A few questions --
Do I need to change the spacers on the seatbelt tower as per the NB installation? I didn't see any mention in the NA instructions and it seems that the NA has a slightly different design here.
Is there any need for spacers where the bar mounts on the parcel shelf or does it just go straight on top of the carpet? When test fitting with the carpet out I noticed there was a gap between the parcel shelf and the bar (there was a raised section -- fuel tank cover plate?)
Do you remove the carpet while lining everything up, or just drill straight through the carpet with it installed?
A few questions --
