sprayed degreaser & washed engine -> rough idle running rich
Posted: Sun Nov 08, 2009 8:28 pm
Ugh...
Went to Wakie for SOTS yesterday and hamx5ter ran like a dream... doesn't use up vital fluids and only needed about $30 of fuel for a day of fun... the thing could be a little swiss watch for how ticktock it goes..
Anyway, I washed the car today, and thought I'd get the muck off the rocker cover from where there had been some oil overflow around the cap (the car had too much engine oil in it, a little over full on the dipstick).
Sprayed some degreaser and the hosed the thing down.. I know I should keep away from the electronics, but not too sure how well I did, since the degreaser sprayed around and I wanted to make sure it was gone..
Anyway, post-wash, the engine idles rough (stumbles, but doesn't stall)... and will rev unevenly if revved (also blows some stream / smoke, but that could be just water in the pipe)...
I've left it alone to dry and will check it out tomorrow.
But sleepless night question though is.... does spraying the engine bay (and around the cowl) let water into the Mania CAI (and thence to the engine), and does the limited amount of water getting in there means I've stilled (almost) hamx5ter's beating heart?
Or are the plugs wet, and all will be well once things are dry...?
I had some sort of hyper-heart-rate / pounding chest thing today, which I took to be a minor heart-attack (will go to the doctor... reeelaax)... or was I simply deja-vu'ing hamx5ter's own travails?
Deen
08/11/2009 20:28:03
Deen
08/11/2009 20:28:03
