Problem Door lock.
JMather
Problem Door lock.
Postby JMather » Tue Aug 25, 2009 4:02 pm
Ive got a small problem with the drivers door lock. :evil:
some times it will unlock... some times it wont. some times i have to let the roof down to get out!
Does anyone know why this is so?
Problem Door lock.
Postby Jeo » Tue Aug 25, 2009 4:17 pm
Locks/unlocks fine from the outside?
Something has probably come loose if it's only working intermittently. Not very hard to pull the trim off and have a poke around and it should be fairly obvious.
Edit: What model?
JMather
Problem Door lock.
Postby JMather » Tue Aug 25, 2009 9:59 pm
It's an NA. I've take the trim off and poked around tried to have a look but alas I found nothing. Well nothing I've seen out of place or jamming. It actually doesn't work either side of the door when it 'catches'. It's just a pain huge sometimes.
broady
Problem Door lock.
Postby broady » Thu Aug 27, 2009 12:40 am
Mate I've been getting this too. Haven't figured out the root cause.
However the area to fix seems to be to have a fiddle around inside the door, at the very bottom.
Signs point to a spring that has worn out or popped out from its position (there are a few threads on this).
人馬一体 NA8
6/5/2010
Problem Door lock.
Postby 93_Clubman » Thu Aug 27, 2009 1:58 pm
sounds like the problem common amongst NAs - take a look at these for an explanation of how to fix:
viewtopic.php?f=18&t=37480&hilit=door+lock
viewtopic.php?f=28&t=35009&hilit=door+lock
viewtopic.php?f=76&t=34774&hilit=door+lock
