Door Card Replacement
Posted: Fri Aug 21, 2009 5:55 pm
You can get the board from any GOOD trimmer and refit the vinyl to the new board, or get the trimmer to do it, or
Just get some s/h door cards.
BUT the most important thing is to make sure the plastic sheet between the door and the card is glued or taped in properly as this is what stops the card getting damaged, if you don't have the plastic get some from bunnings or trimmer.
Terry
Terry
