Wobbly vibratiing noisy passenger seat
AJ
Postby AJ » Sat Aug 15, 2009 8:10 am
it has been mentioned before, most use the solution of cranking the seat right back & reclining the seat back into the rear wall, & to stop it squeaking/wearing in this position, place a small towel where the seat back touches the wall 8)
hope that helps.
XMX5 Rogues
Postby sliq » Sat Aug 15, 2009 10:58 am
AJ wrote:it has been mentioned before, most use the solution of cranking the seat right back & reclining the seat back into the rear wall, & to stop it squeaking/wearing in this position, place a small towel where the seat back touches the wall 8)
hope that helps.
like AJ suggested... i tilt my seats forward when driving with the top down so the sun doesn't fade the fabric.. squeaks like crazy.
but once its been reclined backwards to it's at full rest, the squeaks cease.
Garry
Postby Garry » Sat Aug 15, 2009 10:37 pm
It's more than likely the seat but are you sure it's not the seatbelt tongue rattling against the side panel? There is a little slot for it to fit into in the plastic side panel when not being used.
Otherwise, what AJ said.
JBT
Postby JBT » Sun Aug 16, 2009 8:39 am
Take a passenger with you. :wink:
Quicksilver
Postby Quicksilver » Sun Aug 16, 2009 9:57 am
Try spraying some WD40 or similar on the rail and any hinges etc you can reach. I found mine has a "sweet spot" where it doesn't squeek (or not enough to be annoying). Try different settings of the seat and the back.
クイクシルバ
Moto
Postby Moto » Tue Sep 15, 2009 12:31 pm
JBT wrote:Take a passenger with you. :wink:
Yeah my seat stopped rattling once I put a cute brunette in it :)
RawSouth
Postby RawSouth » Tue Sep 15, 2009 1:22 pm
I find that they can fix most problems :) Including having a full wallet :P
ロードスター
Postby hks_kansei » Tue Sep 15, 2009 2:02 pm
my personal preference would be a cute blonde, however that's for purely aesthetic reasons.
The actual function remains the same regardless of which colour you choose.
StanTheMan
Postby StanTheMan » Tue Sep 15, 2009 2:22 pm
my preferance would be one of middle eastern origin but whatever takes your fancy.
my seatbelt also rattled.....but thats sort of disaperaed sinece the Dijon recently got an upgrade in the noise department. its even pointless to have the radio going.
I also put the seat up aginst the roll bar to stop it vibrating. I have NB8B seats
Szemen
Postby Szemen » Tue Sep 15, 2009 5:32 pm
My seat was squeaking when the rear pleather of the NA seats were rubbing against the rollbar padding on the passenger side, with or without passenger. I just wrapped a T-shirt around the area i get no more squeaks.
Benny
Postby Benny » Thu Sep 24, 2009 4:35 pm
What makes more noise, the girl or the seat? :roll:
taminga16
Postby taminga16 » Tue Sep 29, 2009 4:31 pm
Grazza,
I had a similar problem when I purchased my NB and found that removing the seat and cleaning the rails of fluff and grit with a kero soaked rag followed by a liberal coating of "Dry Lube" (wax stick) fixed it. Take note of the adjustment return spring to see that it cannot make contact and cause squeaking.
Good luck.
Greg.
Fix the cause, not the symptoms.
TieNN89
Postby TieNN89 » Tue Sep 29, 2009 8:05 pm
hey maybe this is the squeal I'm having every once in awhile I haven't been bothered to find it but i'm sure the pass seat is as far backward as possible ...
Old Dude
Postby Old Dude » Tue Sep 29, 2009 9:30 pm
You have to be careful you pick the right Brunette to stop the rattle....... other wise you might get a constant whine :lol: :lol: :lol:
MX 5 2001 Grace Green
NB8B
