Epic wheel painting
PUR157
Epic wheel painting
Postby PUR157 » Wed Aug 05, 2009 1:58 am
That's a nice looking shade...! What is it called?
Now git'r lowered y'hear! :D
Oneness of Man and Machine
philz
Wheel guru
Epic wheel painting
Postby philz » Wed Aug 05, 2009 2:07 am
Sorry but the originals were better can't believe you just killed those magnesium blue te37s.
psquire45
Epic wheel painting
Postby psquire45 » Wed Aug 05, 2009 11:52 am
i think they suit the car much better in silver well done
1998 NB MX5, AVO turbo kit, Adaptronic plug'n'play, RX8 440cc injectors, Fm Brace, DBA cross drilled brakes, cusco rollbar Pedders springs
StanTheMan
Epic wheel painting
Postby StanTheMan » Wed Aug 05, 2009 12:07 pm
well done....did you clear coat them? was there a special sort of paint you used?
@ndrew
Epic wheel painting
Postby @ndrew » Wed Aug 05, 2009 12:52 pm
What sized wheels are they??
MX5CHIC
Epic wheel painting
Postby MX5CHIC » Wed Aug 05, 2009 12:56 pm
Great job and the colour does look a whole lot better, I sprayed my wheels a year ago and one thing people need to know is that you need a lot of patience and good masking skills :lol:
@ndrew
Epic wheel painting
Postby @ndrew » Wed Aug 05, 2009 1:00 pm
Artificial Life wrote:Thanks squire :)
It's a factory Renault colour (427), in DeBeer paint, from Autolac. We double-coated with clear-coat (2pack with hardner) after the base coat, with a small go of 1200+ grade sand paper in the middle.
The wheels are 17*7.5 +44
Do you know if most WRX wheels fit the NC??
Also could you post some higher quality pics when you get a chance?
philz
Wheel guru
Epic wheel painting
Postby philz » Wed Aug 05, 2009 1:55 pm
WRX wheels- you might have problems of it rubbing the inside guard/suspension than the outside.
@ndrew
Epic wheel painting
Postby @ndrew » Wed Aug 05, 2009 3:00 pm
Would 17x5 5x100/5x114.3 +42 fit without any issue??
philz
Wheel guru
Epic wheel painting
Postby philz » Wed Aug 05, 2009 3:17 pm
Do you mean 17x7? if so +42 should be okay.
+55 17x8.5 is okay, since stock is +55, going wider doesn't hurt :wink:
@ndrew
Epic wheel painting
Postby @ndrew » Wed Aug 05, 2009 3:49 pm
philz wrote:Do you mean 17x7? if so +42 should be okay.
Sorry i mean't 17x7.5 + 42
