Fitting Stripes
Posted: Mon Aug 03, 2009 2:04 pm
by tbro
Hi OD,
Use a hairdryer, but look at
http://www.miata.com in the garage section under exterior and there is a full section on how to do it.
I'm thinking of fitting the stripes back on Scooter so will be interested to hear how you go.
Terry
Fitting Stripes
Posted: Mon Aug 03, 2009 2:21 pm
by GP14
The bonnet hump is nothing. Thats probably one of the easiest parts to do. The hardest part is the front bumper. I'd suggest you do that last after you've gotten the knack of how the vinyl works on there. The hair dryer is your friend and so is a helping hand
Fitting Stripes
Posted: Wed Aug 05, 2009 3:00 pm
by Benny
Wet down your car with soapy water ad leave it wet when you are putting the stripes on.
This way, you can move them around a little without sticking them down.
When the water drys, the stripes will stick really well.
If you keep the car dry, whenever you lift a bit of the stripe to get it into the right position, You'll stretch the vinyl, and then the stripes won't look so good.
Fitting Stripes
Posted: Wed Aug 05, 2009 11:23 pm
by Hammer
Ditto Benny's recommendation. Make sure you remove any air bubbles before it dries.
