Advice on NB8B Front Bumper Help!
MX5CHIC
Postby MX5CHIC » Fri Jul 24, 2009 12:46 pm
I need to make a decision on which Bumper to fit to my NB8A before the end of the month.
My bumper was cracked and dented when some fool reversed into me, because the car is black I want a top class repair so have decided to replace the bumper with a new or perfect condition used one.
My questions ;
Has anyone actually installed a NB8B Bumper to an NB8A?
Are the mounting points the same as an NB8A?
What else needs to be modified or replaced to fit one? (apart from headlamps)
I want to use the fog lamp holes (hole) as an air intake so I won't be looking for foglamps.
Anyone have one for sale? .... Mazda Dealers sell them for $475.
Should I keep the existing NB8A look? ........... your opinion?
My car already has NB8B door trims, centre console, tail lamps, wheels and NC Seats - yes, it has a personality disorder.
philz
Wheel guru
Postby philz » Fri Jul 24, 2009 1:00 pm
yes okibi has.
Postby sliq » Fri Jul 24, 2009 2:08 pm
the mounting points are different from what i can recall.
philz
Wheel guru
Postby philz » Fri Jul 24, 2009 3:24 pm
you will need NB8B inner wheel trims which will hold the side of the bumper.
Radiator mounts are the same.
MX5CHIC
Postby MX5CHIC » Fri Jul 24, 2009 8:05 pm
I have borrowed a photo from a forum member and photoshoped it - NB8A with NB8B Front bar, fitted with Morette Headlamps ... think I like it.
Apologies to the forum member whose car I have used :roll:
StanTheMan
Postby StanTheMan » Fri Jul 24, 2009 10:20 pm
yep...Love that. :mrgreen:
Postby Jeo » Fri Jul 24, 2009 10:29 pm
approved
Postby Regie » Sat Jul 25, 2009 4:25 pm
DO IT!! then add a GV lip :)
AB7
Postby AB7 » Sat Jul 25, 2009 6:26 pm
Do it!!! Since your car is black, you'll probably won't notice the gap under the headlight.
MX5CHIC
Postby MX5CHIC » Sat Jul 25, 2009 7:17 pm
OK .. all yeas and no nehs - I think it's looking positive for an NB8B Bar. The gap in the corner problem can be solved by modding the headlamp surrounds. :idea:
Postby Okibi » Sat Jul 25, 2009 9:16 pm
I'll try and find the old thread or take new photos tomorrow.
MX5CHIC
Postby MX5CHIC » Sat Jul 25, 2009 10:57 pm
Thanks Okibi, I spent a few hours searching the forum and found some info and photos of your car - it looks red hot :D
MX5CHIC
Postby MX5CHIC » Mon Jul 27, 2009 1:17 pm
Good News ..... one brand new NB8B Front Bumper on the way :lol:
psquire45
Postby psquire45 » Tue Aug 04, 2009 3:52 pm
hey the old lip of the nb8a bumper did you have any plans for that ? :mrgreen: or was it cracked when the person reversed into you ?
1998 NB MX5, AVO turbo kit, Adaptronic plug'n'play, RX8 440cc injectors, Fm Brace, DBA cross drilled brakes, cusco rollbar Pedders springs
MX5CHIC
Postby MX5CHIC » Tue Aug 04, 2009 4:14 pm
Hi, I have started a thread on the subject of selling the old parts ... viewtopic.php?f=44&t=37857
The Lip had a 50mm crack in it when I bought it off a damaged car, it was repaired and reinforced from behind with steel then repainted black.
The crack and repair was underneath where you cannot see it anyway but I'm not sure if I will seperate it from the bumper before sale as I will be left with a bumper with holes in it from where the spoiler bolts on ..... and buying lip spoilers for NB8A's is very expensive ($750) or nearly impossible to find 2nd hand.
