interior removal guide
16bit
Vehicle: NB8A - Supercharged
Postby 16bit » Fri Jun 19, 2009 9:11 am
anyone know where I could get hold of a free internets interior removal guide for my nb8a?
Postby Hammer » Fri Jun 19, 2009 12:30 pm
16bit wrote:anyone know where I could get hold of a free internets interior removal guide for my nb8a?
they miata.net
Postby Okibi » Fri Jun 19, 2009 2:35 pm
I've pulled most of ours apart as some stage.
I don't think I have photos for most though :? , what did you need advice on removing?
16bit
Postby 16bit » Fri Jun 19, 2009 4:51 pm
Centre console and everything at the front (dash etch). Doors are no worries.
thanks!
mitch_f1
Postby mitch_f1 » Fri Jun 19, 2009 5:26 pm
on the same topic, anyone know the weight loss by taking out carpets, sound deadening, softtop?
RG.net
Postby RG.net » Fri Jun 19, 2009 6:45 pm
same boat, just want the bottom carpet out.
I'll do some fishing around guys.
RG.net
Postby RG.net » Fri Jun 19, 2009 6:49 pm
16bit wrote:Centre console and everything at the front (dash etch). Doors are no worries.
thanks!
Centre console is easy, there are two screws in the centre console (pop the lid, you will see them) and there is one screw attached to the bottom of the dash on each side (they will be covered with a black plastic dot thingy) then you carefully lift it out, try not to damage the boot and fuel opener.
Postby sliq » Fri Jun 19, 2009 6:49 pm
http://www.youtube.com/watch?v=4n_9Nd9bhco
not exactly for an mx5, but you get the gist of it.
RG.net
Postby RG.net » Fri Jun 19, 2009 7:12 pm
http://www.miata.net/garage/DashRmv_89_93.pdf
that should help you with the dash removal 16bit.
Its for an NA, but its all very similar.
16bit
Postby 16bit » Fri Jun 19, 2009 7:45 pm
thanks mate, thats a big help. i am glad I did not just have a crack at it!
de Bounce
Postby de Bounce » Fri Jun 19, 2009 7:48 pm
MXHEVN wrote:Centre console is easy, there are two screws in the centre console (pop the lid, you will see them) and there is one screw attached to the bottom of the dash on each side (they will be covered with a black plastic dot thingy) then you carefully lift it out, try not to damage the boot and fuel opener.
Thought there was a screw under the electric window switch :!: Link
At least there is in the NB8B :shock:
Getting the switch out is a PITA IMHO
Motorkhana Video
TieNN89
Postby TieNN89 » Fri Jun 19, 2009 9:17 pm
yep on the NB8B+ consoles
on the NB8A its under the ash cup thing open it up and hold the lid and pull it upwards should remove it (should be pretty easy)
RG.net
Postby RG.net » Sat Jun 20, 2009 1:06 am
I didnt have a screw there since purchase, lucky me.
16bit
Postby 16bit » Sat Jun 20, 2009 2:18 pm
failed at removing the dash! just could not get it loose. I got a bunch of other stuff out but I could not be bothered in the end.
RG.net
Postby RG.net » Sat Jun 20, 2009 4:04 pm
16bit wrote:failed at removing the dash! just could not get it loose. I got a bunch of other stuff out but I could not be bothered in the end.
Why do you want the dash out anyways?
just strip the carpet, paint it and call it a day.
Users browsing this forum: No registered users and 247 guests
