Front number plate location
Postby sliq » Wed Jun 10, 2009 10:12 pm
i don't think it should be a problem unless you have track days, or it is a very hot day..
Postby Hammer » Wed Jun 10, 2009 10:15 pm
As sliq said, it shouldn't be problem as a daily driver even in summer. Though if you turbo it and the like, I'd be moving it out of the way.
Postby Mr Morlock » Thu Jun 11, 2009 12:34 am
I have a slimline mounted in the nose and have had no probs.
Postby Okibi » Thu Jun 11, 2009 4:48 am
It should be fine for daily driving, but why make the car have to use the fans more or run even hotter.
I've seen bog standard MX-5s with the same plate location as yours overheating on the track but once the plate was moved they ran fine all day.
Just move it out of the way, seems like a no brainer to me.
Postby Regie » Thu Jun 11, 2009 9:38 pm
ive had mine on the track with the plate in that position. ive ran all day without any problems
Postby Okibi » Thu Jun 11, 2009 10:48 pm
There's no doubt that's very possible, but why risk the chance it gets too hot?
Should also note that the NB temp gauge is more of an on/off switch than a true temperature gauge.
RG.net
Postby RG.net » Sat Jun 20, 2009 3:32 am
I have had problems with overheating, hot summer night + blocked airflow = bad.
Just get a mx5plus number plate bracket, They sit the number plate above the bumper opening. For $30, they are good insurance.
