Fixing up license plate dents.
Szemen
Postby Szemen » Mon Jun 01, 2009 11:12 pm
By szemen, shot with Canon DIGITAL IXUS 700 at 2009-06-01
What do I do about it?? If you notice the relfeciton...if its big enough. The bumper is dented in...Would it be tape off the area, sand it down, bondo it, sand, prime, and paint?
Postby bruce » Tue Jun 02, 2009 12:34 pm
That sounds right. Hardest bit will be getting it smooth and matching the paint.
I reckon use the cat on a sticky pad and see if it will buff out... !
Postby sliq » Tue Jun 02, 2009 1:26 pm
just use liquid paper........
Szemen
Postby Szemen » Wed Jun 03, 2009 10:55 am
Not sure about liquid paper...I don't have any at home. I do have a cat readily available so I'll definitley give that a go!
How about the passenger side lights? Notice how its slightly higher then the other side...I've seen other NAs that have a similar characteristic, but i'm trying to get ride of it and making it flush.
Postby bruce » Wed Jun 03, 2009 11:24 am
Pictures of cat used as buffer please.
I noticed that gap. You can actually just grab the back edge with the bonnet up and pull it up gently (a bit of force may be needed) until it lines up. Leaving it like that is like an air intake.
bender
Postby bender » Wed Jun 03, 2009 6:11 pm
I've got the same problem but worse, mine actually have 2 dents from the old screws where it used to hold the number plate. Let me know if you are going to fix it up and what the are the steps involved :)
Szemen
Postby Szemen » Wed Jun 03, 2009 8:11 pm
Cheers philz, I'm getting some ratsback for the intake :P
Hey bender, notice the relfection goes around the two holes...its a physical dent going in, on both, hence the bondo. But I'll definietly take photos if it looks good :P
bender
Postby bender » Wed Jun 03, 2009 8:19 pm
Same with my car, I'll try get a photo
