Boot lip spoiler fitment
Posted: Tue May 19, 2009 5:26 pm
by PUR157
For the guys running the OEM rear lip spoiler on a clubman, do any of you know if the placement of the spoiler will foul the clubman sticker?
ie will I have to remove the sticker to fit the spoiler on (assuming the sticker is in its original position)
Also I've read you only need sikaflex/adhesive to hold the spoiler on... does anyone recommend different?
Posted: Tue May 19, 2009 6:56 pm
by CheyneX5
PM green_comet mate, he mentioned something about the clubman sticker having to sit about 3mm lower or something?
Posted: Wed May 20, 2009 6:28 pm
by PUR157
Ah alrighty, thanks for that Cheyne
Anymore advice peoples?
Posted: Wed May 20, 2009 11:22 pm
by green_comet
You can fit it without moving the sticker, but there will be a very small gap between the spoiler and the top of sticker. I lowered my Clubman badge a few mm to make it look right.
Posted: Thu May 21, 2009 3:27 pm
by PUR157
Thanks green_comet, that's just the info I was looking for!
Posted: Mon May 25, 2009 4:01 pm
by Benny
Personally, I wouldn't just use Sikaflex to mount it with however.
The aerodynamic forces at over 100km/h would just be too great and you wouldn't want it flying off.
I've seen spoilers that were bolted on just rip out of the metal at high speeds.
Go down a freeway at 100km/h, and stick your had out of the window, then tell me if you think Sikaflex would hold the spoiler on.
Posted: Mon May 25, 2009 11:23 pm
by PUR157
That's exactly why I asked... :D
I don't know the adhesive properties of sikaflex first hand so I'm at a loss to judge whether or not it's sticky enough
I appreciate the tip though, gives me more to think about
Posted: Tue May 26, 2009 1:09 pm
by GP
Mines bolted on with these little clips that clamp onto the edge of the bootlid.
Posted: Tue May 26, 2009 10:35 pm
by Garry
I have an NB8B rear spoiler and Mazda thinks a few bolts and double sided tape will hold it on. It did until my car was parked outside on a really hot day and the spoiler buckled lifting up from the bootlid. I had to get a new spoiler and used the bolts and sikaflex instead of the double sided tape to attach it this time. It's been there for 4 years and seen some really hot days since and hasn't moved.
Posted: Sat May 30, 2009 11:04 pm
by PUR157
Thanks for all the advice people, very useful advice!
