Painting Rocker Covers
TieNN89
Postby TieNN89 » Sat May 16, 2009 7:05 pm
Hi There,
Are there any instructions out there as to how to paint rocker covers like whats the prep etc...
Also does anyone have pictures of there painted covers
I'm not sure what colour to paint it I'm thinking Red atm with the wrinkle finish
wun911
Postby wun911 » Sun May 17, 2009 2:11 am
I did mine a while back.
Get the cam cover gasket and the glue stuff that goes between the gasket and the cover. The bolts have torqe specs and are done up in a specific order instructions on miata net if your anal.
I kinda regret doing it red now it gets dirty easy and hard to clean stains off it. If I were to do it again I would go black. If I were to do it again again I would rather spend the time to polish it (less weight easy to clean).
If you heat the cam cover then paint it it looks better and paint will dry faster (takes forever to dry and smells bad).
[url=http://g.imageshack.us/img148/dscf0711zl1.jpg/1/][img]
[URL=http://g.imageshack.us/img353/dscf0708we9.jpg/1/][IMG]
every ounce counts
TieNN89
Postby TieNN89 » Sun May 17, 2009 10:04 am
nice nice
ah that was my fear as well the keeping it clean :(
Adam_NAclubman
Postby Adam_NAclubman » Sun May 17, 2009 5:12 pm
I was going to do mine in crackle-finish red but my cousin got bored one afternoon and used plain VHT heatproof red. It looks ok, but not as good as the way I was going to do it. We did the inlet manifold in satin black while we were at it, I just need to try and do the throttle body now.
Rocker cover was degreased then sprayed, manifold was sandblasted then sprayed
fattima
Postby fattima » Sun May 17, 2009 6:21 pm
Here is mine, I did a couple of weeks back in black VHT wrinkle paint. Prep was to give it good wipe down with degreaser then three good wipe downs with prepsol (get it from auto paint places) till the rag I was using came away clean. Dried it with a heat gun, taped up any areas I did not want painted such as PCV valve hole and oil filler hole. Did one good coat of paint let it sit for 5 minutes then another coat and then used a heat gun to get the wrinkle finish, I then let it dry for a week inside the house so it was warmer than the garage. Used a razor blade to cut the paint of the raised lettering then finished with a few different grades of wet and dry.
TieNN89
Postby TieNN89 » Sun May 17, 2009 8:21 pm
nice
so how long does it take to dry?
and i need a heat gun to get the wrinkle finish? would a hair dryer work?
fattima
Postby fattima » Sun May 17, 2009 11:52 pm
Hair dryer should be fine, you don't have to use one but you get a better wrinkle finish with one. The can recommends 5 days to let the paint fully cure, but it should be OK after a few hours as long as you don't put pressure on or scuff the painted surface.
wun911
Postby wun911 » Sun May 17, 2009 11:58 pm
I chucked mine into an oven and just cooked it overnight...
Oh you may want to chuck it into the oven and pre-heat it before you paint aswell...
every ounce counts
TieNN89
Postby TieNN89 » Mon May 18, 2009 12:18 am
will my oven fit it is another question lol
PUR157
Postby PUR157 » Mon May 18, 2009 1:02 am
ALSO whether or not your partner/family appreciates engine oil all over their sunday roast... :mrgreen:
Oneness of Man and Machine
wun911
Postby wun911 » Mon May 18, 2009 2:28 am
nahh no engine oil....
I cleaned it properly, I put it though a dish washer (it fits and its all clean in 45 min)
every ounce counts
daffyflyer
Postby daffyflyer » Mon May 18, 2009 12:06 pm
wun911 wrote:nahh no engine oil....
Im never eating at your house! :mrgreen:
Developing a Car Industry Game - Visit www.automationgame.com
White 1994 MX5 Clubman - Carco Built NA Motor - 101kw ATW @ 7500rpm
mx52nv
Purple Porsche Eater
Postby mx52nv » Mon May 18, 2009 1:33 pm
:shock: :shock: :shock:
Postby bruce » Mon May 18, 2009 3:24 pm
He put it in the dish washer because it made too much of a racket in the washing machine.
Benny
Postby Benny » Mon May 18, 2009 4:26 pm
bruce wrote:He put it in the dish washer because it made too much of a racket in the washing machine.
To say nothing about the noise it would have made in the tumble dryer! :mrgreen:
