Seats - Cobra Monaco Pro vs. Sparco Srpint V
hot rod
Postby hot rod » Thu Apr 23, 2009 6:29 pm
I was wondering if anyone might have an opinion as to which one of these seats is better value?
Is the Cobra a bolt in job like the Sparco?
Are there any others I should be looking at in this price range? (under $500)
Basically I can't fit in the car with a helemt on, I'm 6 foot tall and like to sit as upright as a I can.
Sparco Sprint 5
http://www.revolutionracegear.com.au/index.php?PCID=10409&PSO=245&PSID=4473005_20&PSV=Primary&CDO=
Cobra Monaco Pro
http://www.revolutionracegear.com.au/index.php?PCID=10421&PSO=245&PSID=4665005_20&PSV=Primary&CDO=
bigdog
King of the kennel
Postby bigdog » Thu Apr 23, 2009 9:13 pm
Cobra Monaco seat angle is different to Sprint - you will have less fore-aft movement with the Monaco, and the Monaco is harder to adapt to the MX5 rails. Sprints seem a better option, and I suspect they are better built.
fattima
Postby fattima » Thu Apr 23, 2009 11:48 pm
I'm 6 ft and find the Sparco sprint V on the original MX5 rails sits too high for me. No experience with the Cobra. I run a cheap OBX seat and find it really good position wise, quality is a bit lacking.
green_comet
Car Detailing Guru
Postby green_comet » Fri Apr 24, 2009 9:13 am
I have been in the Sparco Sprint V, and found it pretty comfortable. Same as Fattima said, the seat height is an issue for me also being 6ft.
Im trying to track down a set of Cobra Roadster 7 Seats for my car, they should sit pretty low and suit the MX5 quite well.
Like this but in black...
http://www.cobraseats.com/roadster_7.htm
Here are some in an MX5.
hot rod
Postby hot rod » Fri Apr 24, 2009 10:00 am
Thats for the tips guys, probably would prefer something with a a bit more hip support.
Fattima - Did you try bolting the Sparco seat directly to the floor? Is that possible?
mx5racing
Postby mx5racing » Fri Apr 24, 2009 10:46 am
We run these Autotecnica ones -
http://www.autotecnica.com.au/seats.html
We use the A999 and A1098's in the NC's (also used them in NA/NB)
They are a great budget priced seat and come with the side plates which we cut down to use with the factory runners. In the NC we have fit big Nick, Steven Head and others well over 6ft in the cars. The A1098 has additional padding which can be removed for track days if you want additional height.
Well worth considering and about half the cost of the "name" brands.
They SEATS are also ADR approved.
Matty
Postby Matty » Fri Apr 24, 2009 11:55 am
green_comet wrote:I have been in the Sparco Sprint V, and found it pretty comfortable. Same as Fattima said, the seat height is an issue for me also being 6ft.
Looking at these, they appear to have no inbuilt support for the rear squab. I believe they are designed to use the rear bulkhead for back support...
fattima
Postby fattima » Fri Apr 24, 2009 6:32 pm
hot rod wrote:Fattima - Did you try bolting the Sparco seat directly to the floor? Is that possible?
No I didn't as I still wanted an adjustable seat. There are raised sections where the original seats runners mount to the floor they may get in the way when mounting directly to the floor.
hot rod
Postby hot rod » Mon Apr 27, 2009 2:49 pm
mx5racing wrote:We run these Autotecnica ones -
Thanks for that info, very helpful.
Is there anywhere I can look at the A999 in person, who stock these?
bigdog
King of the kennel
Postby bigdog » Mon Apr 27, 2009 3:25 pm
I've seen Autotechnica seats at Repco and Autobarn stores... but I haven't seen these particular ones, they all seemed to be the reclining jobbies.
fattima
Postby fattima » Mon Apr 27, 2009 5:43 pm
The Autotecnica importers are in Thomastown in Melbournes northern suburbs (48 Northgate Drive). Good guys up to deal with and they will let you check out what they have. You can't buy directly from them but they organised for me to purchase some stuff from an auto trimmers a few doors up from their offices.
Alex
Postby Alex » Mon Apr 27, 2009 5:58 pm
If someone in Syd wants a A999, I've got one for sale Here (also have a Sprint V)
shameless plug
while we are here though, mx5racing would you be able to put up a quick guide on installing the A999 in the NA/NB (would say NC too but I don't know if many want to do without the airbags)
hot rod
Postby hot rod » Tue Apr 28, 2009 2:55 pm
Thanks agian for that info, I don't live far from Thommo so I'll go there and have a look at one in person.
Yes any help installing these seats in an NA would be of great help!
cheers
booki89
Re: Seats - Cobra Monaco Pro vs. Sparco Srpint V
Postby booki89 » Sat Sep 20, 2014 8:21 pm
Bit of a thread bump, but I purchased the A999 (autotecnica seat) and it sits higher then stock with the universal rail and factory sliders!
How did you get it to fit in a NA mx5? Was there a drop in height?
