Wax Buffing Machine
den525
Wax Buffing Machine
Postby den525 » Tue Mar 31, 2009 6:20 pm
Does anyone know any good ones? I have been using just a waxing cloth in the past, and it gets pretty tiring.
2006 MX5 NC Galaxy Grey (tan soft top)
2009 BMW 135i (Black)
MX5CHIC
Wax Buffing Machine
Postby MX5CHIC » Tue Mar 31, 2009 7:20 pm
Considering waxing is not done everyday I just bought a machine from Repco, forget the brand but it is orange and black.
Important to consider is a variable speed type as you should never wax / polish over 1800/2000 rpm or risk burning in your polish. Also a padded rubber base is important and get yourself a few quality buffing and polishing mitts so that you always have a clean one on hand.
philz
Wheel guru
Wax Buffing Machine
Postby philz » Tue Mar 31, 2009 7:21 pm
Just for waxing? or do you want it for polishing as well?
For waxing only, Mother's has a kit, or I'm sure one of those $20-$30 el cheapo ones will do the job.
However, for polishing, I would be using a RO machine.
marcusus
Wax Buffing Machine
Postby marcusus » Tue Mar 31, 2009 7:24 pm
I got my mate just some random orbital buffer from Bunnings. Ozito brand or something I think. I just made sure that it had the velcro bit on the bottom so the pads I bought off Waxit would go on.
It works a charm, and is definitely a lot cheaper than the full on options you can get.
Wax Buffing Machine
Postby Mr Morlock » Tue Mar 31, 2009 8:35 pm
Forget machines which are not built for purpose. A buffing machine can be used for cutting and polishing. Best bet go to a proper paint supplier one that supplies to professionals and ask them for advice on the different machines.these days they usually have a choice. My local guy was also a painter by trade and you get the right advice. If you buy the right tool it will last you a very long time. If you know any pro painters also not a bad idea to watch them in action. I have a 2 speed machine which I have used for a variety of jobs including heavy sanding and rust removal etc. The right advice avoids getting a machine that is too fast or not powerful enough for different work.
JBT
Wax Buffing Machine
Postby JBT » Tue Mar 31, 2009 9:48 pm
As a non-professional, you're best to stick with a random orbital buffer/sander for polishing and very minor swirl removal.
A rotary buffer/sander (similar in operation to an angle grinder) can easily wreck the paint at worst and leave holograms and swirls at best in the wrong hands. :shock:
As with anything, you get what you pay for. Google Autopia, Detail Paradise or even Meguiars for info and/or videos on machines in use.
