Hey guys,
Would anyone know where I would be able to pick or order one of the Din pocket as there is a ugly hole in my console now that I got a aftermarket deck. Located in Syd btw
NA6 Din pocket
- Learner Driver
- sliq
NA6 Din pocket
try your wreckers mate.
i found a second hand mazford one for about $5:
Mazford Parts Plus Pty Ltd
1 Marigold Street Revesby
2212, Sydney Australia
Telephone: Intl +61 2 9772 2222
Fax: Intl. +61 2 9773 9000
Email: info@mazford.com.au
- Mr_Q
NA6 Din pocket
Your local Mazda spare parts department for about $10.
Mister Q
NA6 Din pocket
just making sure you know, you can get an OEM NA8 'tombstone' that fits aftermarket single DIN headunits much better and with it you could also get the NA8 fill in pocket too. because as you've probably realised the gap is about 12mm bigger than a regular single DIN MAZDA/FORD pocket.
all up the price should be about $110 from mazda. i have the same ugly hole and i'm over it. i asked the question too, so just giving you the answer i got basically.
good luck!
good luck!
