Driver Sparco Sprint Install
Posted: Mon Feb 09, 2009 6:30 pm
by Spranga
Can anyone who has done it tell me the best way? I have heard it is very easy to mount to stock frame? I have not had time to really look at it but I assume I need to make a few more holes in the subframe and bolt it on with some high tensile bolts?
Thanks
Posted: Mon Feb 09, 2009 6:51 pm
by mx52nv
From memory, you just redrill the OEM rails to fit the Sparco Sprint's bolt position.
That is what was done in Roderic's NA.
Posted: Wed Feb 11, 2009 6:50 pm
by Spranga
Thanks I will have a look at it. Sounds easy.
Posted: Wed Feb 11, 2009 8:41 pm
by 16bit
its not - especially if got one of the italian accurate bases like I did. took me farkin ages but measure 10 times and drill once.
Posted: Fri Feb 13, 2009 6:51 pm
by Spranga
[quote="16bit" measure 10 times and drill once.[/quote]
will do. Thanks mate.
