Can anyone who has done it tell me the best way? I have heard it is very easy to mount to stock frame? I have not had time to really look at it but I assume I need to make a few more holes in the subframe and bolt it on with some high tensile bolts?
Thanks
Driver Sparco Sprint Install
- mx52nv
- Purple Porsche Eater
- Vehicle: Non MX-5
From memory, you just redrill the OEM rails to fit the Sparco Sprint's bolt position.
That is what was done in Roderic's NA.
Thanks I will have a look at it. Sounds easy.
- 16bit
its not - especially if got one of the italian accurate bases like I did. took me farkin ages but measure 10 times and drill once.
[quote="16bit" measure 10 times and drill once.[/quote]
will do. Thanks mate.
