Real or Not?
Real or Not?
Postby Hammer » Tue Feb 03, 2009 10:43 pm
Is the bonnet on this NA for real or a photoshop muck up using a Lotus Elise bonnet? I got the photo from Max Power website, but what they're selling on this photo are the lights. No mention of the bonnet.
If it's real, do you know who makes it? I need to know if they make one for an NB.
The side intake vents certainly makes it look like a photoshop muck up. :?
Real or Not?
Postby sliq » Tue Feb 03, 2009 10:48 pm
it looks very fake to me hammer. the front bummer doesn't look naturally shiny. and the light on the vents on the LHS doesn't look like its coming from the correct angle
Real or Not?
Postby Jeo » Tue Feb 03, 2009 10:59 pm
I'd say fake. Lots of little things don't look quite right.
crzymx
Real or Not?
Postby crzymx » Wed Feb 04, 2009 1:24 am
Look at the light source, and the way the lights hitting the car. why would you want this anyway, if your gonna immitate the elise like that you should just buy one..
DIY is the new black!
philz
Wheel guru
Real or Not?
Postby philz » Wed Feb 04, 2009 1:31 am
That bonnet won't fit even it was real, the air vents will be too low and will hit the engine and other parts, due to the bonnet being made for an Elise which has no engine at the front.
crzymx
Real or Not?
Postby crzymx » Wed Feb 04, 2009 1:36 am
Regardless, zoom engineering does do a variation.
http://www.auto-otaku.com/home/2008/02/ ... -prix.html
half way down the page you will see a pic.
Real or Not?
Postby Hammer » Wed Feb 04, 2009 1:22 pm
crzymx wrote:Look at the light source, and the way the lights hitting the car. why would you want this anyway, if your gonna immitate the elise like that you should just buy one..
To improve airflow throught the engine bay of my SP.
crzymx wrote:Regardless, zoom engineering does do a variation.
Thanks for the link. Some good cars there.
Does anyone know where I can get a bonnet like this for an NB8B in Australia?
wun911
Real or Not?
Postby wun911 » Wed Feb 04, 2009 1:30 pm
So with that would you remove the engin undertray?
every ounce counts
Real or Not?
Postby Jeo » Wed Feb 04, 2009 1:46 pm
Hammer wrote:Does anyone know where I can get a bonnet like this for an NB8B in Australia?
Probably won't help you, but I've been talking with JRacing here in Canberra about sourcing something like that for my NA. They said worst case scenario, they can always modify a stock bonnet. I'm sure most other body shops could do the same.
And awesome link by the way there crzymx.
Real or Not?
Postby Hammer » Wed Feb 04, 2009 2:14 pm
wun911 wrote:So with that would you remove the engin undertray?
No. Coz according to the articles as referred to in this thread, they found when the undertray was removed, that actually increased the pressure inside the engine bay, reducing the pressure differential between inside and outside the bonnet. Which means, the airflow through the radiator and Intercooler slowed down, thus making them less efficient in removing heat.
It seems the trick is not to ram more air into the engine bay, but to increase the exit/exhaust of it, so air will flow through it quicker.
philz
Wheel guru
Real or Not?
Postby philz » Wed Feb 04, 2009 2:27 pm
yes there is, It's Garage Vary, you can get it as a full bonnet, or just that cut out, and you fit it onto your oem bonnet.
full bonnet- in carbon fibre or FRP
Or just the "air vent" by itself
Real or Not?
Postby bruce » Wed Feb 04, 2009 2:39 pm
Piccie is a fake. Bonnet would hit the motor.
Real or Not?
Postby Okibi » Wed Feb 04, 2009 2:50 pm
I think it's fake based on the dark red on the far side of the nearside cut out.
Vary bonnet is the way to go, but i'm bias :mrgreen:
Real or Not?
Postby Hammer » Wed Feb 04, 2009 5:10 pm
Thanks Philz. Looks just like what I'm after.
Okibi, how has yours faired? How long have you had it? Any pros and cons? Are those two indents at the front for the bonnet pins?
corners
Vehicle: ND - Supercharged
Real or Not?
Postby corners » Wed Feb 04, 2009 5:31 pm
Wasnt that john player special car for sale not long ago??
