Fitment of N Power style bar to NB8A
Postby sliq » Thu Jan 22, 2009 8:46 pm
have you got a photo of it?
if it is similar to the racing beat style II, then you definitely need to do some hacking.
there are other style bars i have seen that simply bolt into where the seatbelt towers are. i wouldn't bother buying one of them. they attach to the chassis so flimsily, it would probably mouse trap you if a breeze went past.
Postby sliq » Fri Jan 23, 2009 12:55 pm
fundies, i don't think this one requires any hacking
the ebay description says it bolts straight on.
i think this is what the installation should look like clicky
the one that requires hacking is the racing beat one/or replicas of it. this is what the installation requires you to do clicky
Postby Hammer » Fri Jan 23, 2009 1:16 pm
Looking at the photo from ebay. This looks more like the RB Style 2 Bar. In fact I think this is the OBX version which is a direct copy of the RB Style 2 bar. See MX5 Mania's website (photo below)
The other reason I think this is more like the RBS2 & OBX bar is the photo (below) from ebay. The vertical support frame with a nut (circled red) requires to be bolted into the upright. This will require the black plastic trim to be cut out to accommodate. As per Sliq's 2nd link.
But I could be wrong. Having said that I have the RBS2 bar and it looks very similar to the photo.
Postby Regie » Mon Jan 26, 2009 5:37 pm
yep thats the one i have. i had to do some hacking just on the plastic bits on the seatbelt mount tower bits
Red Dragon
Postby Red Dragon » Wed Jan 28, 2009 9:24 pm
These are great, no hacking and 10 minute fit
www.frenzybars.com
Postby sliq » Wed Jan 28, 2009 11:10 pm
i think its a good idea that the style bar requires hacking for it to be fitted to the chassis - you have the peace of mind that its more secure than just bolting in one or 2 bolts.
