Where do pplz get the magnecore leads from??
wun911
Postby wun911 » Fri Jan 02, 2009 12:30 pm
Apart from mania where are you guys getting the magnecor leads for NB8B from (only need 2 leads). Repco and autobarn dont stock them. Do they make them in 8.5mm for the NB8B?
every ounce counts
Postby sliq » Fri Jan 02, 2009 3:17 pm
they aren't worth getting overseas since the cost of shipping and conversion rates end up working out more than mania.
i remember looking at them on goodwin racing, cost of shipping was more than that of mania.
TieNN89
Postby TieNN89 » Fri Jan 02, 2009 7:31 pm
I got mine from MX5parts
Steampunk
Postby Steampunk » Sat Jan 03, 2009 6:42 pm
sliq wrote:they aren't worth getting overseas since the cost of shipping and conversion rates end up working out more than mania.
And here I am thinking for the longest time that they are made in Australia.... I guess they aren't....? :roll:
Try ringing around the bigger Autobarns cause some shops stock things others don't, otherwise try some local tuning or hot rod shops Wun.
If you're gonna get something from overseas, may as well check out what Moss Motors have in stock.
BTW, exactly which part of the "Body, paint or trim" do Ignition Leads go on? :P :wink:
wun911
Postby wun911 » Sat Jan 03, 2009 11:05 pm
The ones I want are 8.5 mm I think they are red and thus they look good, thus its body paint and trim.
I know +0.5 mm thickness is added weight but I hope this will slove my stumbling issues on the track when the car gets hot.
Im going to get them from mx5 parts uk...
every ounce counts
Postby sliq » Sun Jan 04, 2009 9:34 am
wun911 wrote:I know +0.5 mm thickness is added weight but I hope this will slove my stumbling issues on the track when the car gets hot.
did.... i.... just.... hear.... BUT....?!
that is very unlike the prince of liteness.
TieNN89
Postby TieNN89 » Sun Jan 04, 2009 11:33 pm
lol
Postby Okibi » Mon Jan 05, 2009 12:37 am
I got mind from Flyin Miata many moons ago.
pcmx5
Postby pcmx5 » Mon Jan 05, 2009 3:09 pm
Many of the gun tuners here(Maztech, Dalton auto and i think Dyson's) use Hurricane sillacone leads sold by Geelong Tune Up specialists,13 Dendle st Grovedale 3216 ph.52416655.
I visited one sat am and got a set for $100 but think they are more expensive than that normally.
Peter
wun911
Postby wun911 » Mon Jan 05, 2009 10:33 pm
Many moons ago? How long do they last? I'm chaning mine its only done 80k?
every ounce counts
green_comet
Car Detailing Guru
Postby green_comet » Sat Jan 10, 2009 11:16 am
I got my leads from Qld Ignition leads.. http://www.qldignitionleads.com/
They are 9mm spiral wound.. Very good mob to deal with Wun, and the quality is top notch.
Postby manga_blue » Tue Jan 13, 2009 5:55 pm
Wun, these guys are in Mitchum, specialising in ignition for performance and race cars (often a nice range of vintage and current open wheelers there). They make up leads that match your requirements on the spot from a pretty big range of leads, caps, etc as well as your own bits. It works out a lot cheaper and quicker than name brand parts and you get to test them there and then. They'll also tell you first if your old leads really need replacing or not.
http://www.performanceignition.com.au/
Postby manga_blue » Tue Jan 13, 2009 6:03 pm
... oh, and they also stock Magnecor, in big spools, so they may be able to replace a damaged lead or two with a matching one between your existing connectors.
nfs13b
Vehicle: 10AE - Turbo
Postby nfs13b » Thu Jan 15, 2009 1:20 pm
When I got mine done I contacted the distributor in NSW and they actually came out and the guy made un the magecore leads to the length I wanted etc. This it cost me $80 fo the 4 of them. But that was the thicker leads.
http://www.magnecor.com.au/distrib.html
MX5 13B - NFS Racing
PRO-MX5 PB 7.46 @ 179mph & 1.07 60ft
russs
Postby russs » Fri Jan 16, 2009 7:14 pm
What he said... Performance Ignition made mine for the NB. They will need your old leads.
Galaxy Grey NC.
Users browsing this forum: Google [Bot] and 3 guests
