Chrome Fuel Door on NC - comments please!
CoffeeBoss
suntory
Postby CoffeeBoss » Tue Dec 30, 2008 4:49 pm
So, I was quite ambivalent about the whole chrome fuel door look on the NC until fairly recently. It started with approving glances at them on the new Audi TT's, which i thought looked quite ok. Then i saw some NC's with them at the Illawarra Fly Run, and decided i 'needed' one.
The result is, quite honestly, blingier than i had hoped.
In lower light it looks better.... i'm thinking perhaps if it was less chrome, it might suit the car more. Or should i just revert back to standard? Interested to hear what people think - suggestions, criticisms, questions, murmurs of discontent all welcome!
Matt
Postby Hammer » Tue Dec 30, 2008 5:59 pm
Looks good. Leave it on.
It ties in the other chrome parts of your car (ie. chrome strips on the deck, tail & head light trims, and to a lesser extent the silver alloys).
My SP came with one as standard and I'll not have it any other way.
wun911
Postby wun911 » Tue Dec 30, 2008 6:02 pm
It looks heavy...
every ounce counts
PUR157
Postby PUR157 » Tue Dec 30, 2008 9:56 pm
If you think it looks too bling.... you could attack it with a scourer?
or some light abrasive... :mrgreen:
give it the brushed look
I reckon it would fit in better if you had a few more matching accents?
Oneness of Man and Machine
crzymx
Postby crzymx » Wed Dec 31, 2008 3:49 am
I think you just trying to give yourself a reason to not like it. Just leave it on, most nc's have it anyway for a reason.. it looks good.!
DIY is the new black!
StanTheMan
Postby StanTheMan » Wed Dec 31, 2008 7:53 am
I think it looks great.
I mean its not exactly the same as 19" cromies is it.
CoffeeBoss
suntory
Postby CoffeeBoss » Wed Dec 31, 2008 8:14 am
wun911 wrote:It looks heavy...
Haha, classic Wun! We are talking about an NC though... :D AND, it has a rubber seal which the standard item doesn't so technically there is an improvement!
StanTheMan wrote:I think it looks great.
Sure, but your still thinking along those lines (shudder)
PUR157 wrote:If you think it looks too bling.... you could attack it with a scourer?
See, i have been thinking along these lines. More matching accents would be too much chrome for my tastes, which leaves the scourer option. I really need something to practice on before i go attacking it though. I mean, that 'brushed aluminium' look is simply that, right? I just dread attacking it and being left with a part that looks like it fell off the car at some point.
Postby Mr Morlock » Wed Dec 31, 2008 10:47 am
I am not sure if the chrome is on plastic or metal but in either instance using any abrasive is a crazy idea. All it will do is scratch the surface and you will not achieve a so called brushed or satin look. Scouring or scratching the chrome may also introduce a micro crack(s) and then the chrome will start to lift from the substrate. Earlier comments that it was in keeping with some of the chrome look on the rear of the car make sense to me. Mazda are currently using metallised ( high lustre appearance) bezels on their rear lamps so the theme is in place.
Garry
Postby Garry » Wed Dec 31, 2008 10:18 pm
If it's the same as the SP one dont use anything more harsh on it that pure wax. I found out the hard way when I tried to clean mine with chrome cleaner. It wont go brushed it'll just look pox.
Looks fine how it is to me, though isn't there a satin one available too? Or am I getting it confused with the RX8 one?
PUR157
Postby PUR157 » Thu Jan 01, 2009 10:13 pm
Apologies for not making it clear... the comment was made purely in jest... :lol:
I would certainly think tbird would think very carefully before doing anything so permanent to something that retails well in the $200 mark?
How about covering it with some satin contact of sorts?
Or would that kill the finish as well?
CoffeeBoss
suntory
Postby CoffeeBoss » Mon Jan 05, 2009 3:55 pm
PUR157 wrote:Apologies for not making it clear... the comment was made purely in jest... :lol:
Oh, that was understood! I don't take me too serious, so don't you make that mistake either!
PUR157 wrote:I would certainly think tbird would think very carefully before doing anything so permanent to something that retails well in the $200 mark?
Actually, since i purchased this from Moss Motors with a bunch of other things before the dollar went south, it came in under that thankfully.
Garry could have the tip here, i believe. I might hit it with some wax before i decide i am done with it.
It's a pity, because Moss Motors only list the one finish on their website, but the image supplied does not really illustrate just how 'chrome' it is!
Still: It does say chrome. I should have known better :D
philz
Wheel guru
Postby philz » Mon Jan 05, 2009 4:45 pm
If you want a truth, honest and short answer- It looks crap.
Even if it was on an NA or NB it would still look crap, because it looks very tacky and cheap.
Unless it has that zoom engineering style, where has the bludge etc.
CoffeeBoss
suntory
Postby CoffeeBoss » Mon Jan 05, 2009 4:56 pm
Hey Phil,
all good, i'm an advocate of 'Truth In Posting' ... ha!
philz wrote:Unless it has that zoom engineering style, where has the bludge etc.
Don't follow..... pics?
mx52nv
Purple Porsche Eater
Postby mx52nv » Mon Jan 05, 2009 5:09 pm
I think philz meant the following:
Zoom Engineering fuel lid :mrgreen:
*EDIT* they only fit NA & NB MX5 atm so no go for the OP or NC owners
Postby sliq » Mon Jan 05, 2009 10:31 pm
that's the same one on the mini cooper i believe.
