Oh, theres water in my battery well..
crzymx
Postby crzymx » Sun Dec 14, 2008 9:37 pm
Well, after doing some work with my sub, i discovered a nice spot of rust. From there i noticed an even nicer puddle of H2O. So now i am left with the option to neutralize the rust (easy fix, got someone to do it for free) however i dont know where the water came from, and i want to get rid of and prevent future leaks. Anyone had this problem. Ideas? help?
Thanks
DIY is the new black!
wun911
Postby wun911 » Sun Dec 14, 2008 11:25 pm
the battery is sealed??
every ounce counts
Alex
Postby Alex » Mon Dec 15, 2008 4:50 am
the battery is sealed but it's still better to get rid of the water, there should be a drain plug under there somewhere to let it all out
Jimmy
Postby Jimmy » Mon Dec 15, 2008 12:24 pm
I has this exact problem in my old five except much worse. I had to get the battery well cut out and then a new plate welded in. The water was coming from the soft top and also surprisingly the rear right tail light. I fixed the soft top (had a few holes in the rain rail) and then moved onto the tail light. When i removed it, the rubber seal had completely perished, so when water ran down the water well around the boot, it ran straight into the boot (not all of it of course but enough to do damage). I fixed it with lots of silicon but a new seal is the way to go.
Best way to check is to give the tail light a blast with a high pressure hose. Then lift the boot lid and see if there's any water coming in.
crzymx
Postby crzymx » Tue Dec 16, 2008 12:37 am
Hrm, well i guess ill have to have a better look. Ill get to neutralising it, but its a pain of the arse. Thanks for the input, ill check seals and stuff and try and locate the leak. Sounds like it woudl be the soft top, it leaks from everywhere these days.
New soft top time.. great
lukey
Postby lukey » Wed Dec 17, 2008 1:15 pm
I found a very very similar thing last week
I did realise that water was leaking between the fibreglass rear mid section and the panelling and leaked through when I was using high pressure water as the clips for the bootlining were where the water was getting through.
I havent had a chance to pull it all apart and rust proof cut-back and respray but that will happen very shortly '
Where are these so-called drain plugs you speak of Alex? I couldnt find one
1997 MX5 Montego Blue - Gone
1999 MX5 Brilliant Black - Gone
2004 MX5 SE Titanium - OOOOOHH BABY!!!!
'Jinbai Ittai' - Rider and Horse as one
Postby bruce » Wed Dec 17, 2008 4:49 pm
There is no fibreglass in a 5 (unless your car has been severely Liberaced). The beaver panel is plastic.
lukey
Postby lukey » Thu Dec 18, 2008 10:21 am
I dunno I'm still very much a Noob Bruce
Duj
Postby Duj » Wed Dec 24, 2008 6:59 pm
Ewww gotta love that musky 'wet boot' smell :lol:
Currently driving an 01' GS300 2jz...
crzymx
Postby crzymx » Wed Dec 24, 2008 11:38 pm
No boot smell at all, hasnt affected carpet just the metal :@
