Clean Headlights.
Clean Headlights.
Postby Mr Morlock » Fri Oct 24, 2008 10:00 am
You can polish them with car polish and this works very well but do not over do it with a heavy cut. The polycarbonate lenses are coated at time of manufacture but they tend to deteriorate with time and weathering.
philz
Wheel guru
Clean Headlights.
Postby philz » Fri Oct 24, 2008 10:22 am
mothers plastic polish
Clean Headlights.
Postby Jeo » Fri Oct 24, 2008 10:29 am
philz wrote:mothers plastic polish
+1
Clean Headlights.
Postby bruce » Fri Oct 24, 2008 10:48 am
Inside?
Clean Headlights.
Postby sliq » Fri Oct 24, 2008 1:12 pm
on NB's, you'll have to rip off the front bar to clean the lights from the inside.
Clean Headlights.
Postby Mr Morlock » Fri Oct 24, 2008 1:46 pm
You clean the lense from the outside. The lense is hot melt glued to the housing.
GP
Clean Headlights.
Postby GP » Fri Oct 24, 2008 5:49 pm
Brasso works a treat :D
Graham
16bit
Vehicle: NB8A - Supercharged
Clean Headlights.
Postby 16bit » Fri Oct 24, 2008 8:01 pm
going to give mine a go with micro fibre this weekend.
irwin83r
Clean Headlights.
Postby irwin83r » Fri Oct 24, 2008 8:43 pm
+1
+2
on the outside
PUR157
Clean Headlights.
Postby PUR157 » Fri Oct 24, 2008 11:01 pm
Just make sure you don't jump straight to the most abrasive compound you have... I've read that it's best to work your way up to consecutively rougher compounds if you find the finer ones don't work... coz then you'd just spend the rest of the day polishing back the swirls
Oneness of Man and Machine
Clean Headlights.
Postby sliq » Sat Oct 25, 2008 9:00 am
yakob wrote:
sliq wrote:on NB's, you'll have to rip off the front bar to clean the lights from the inside.
is there a tutorial anywhere? coz im sure most of the grime is on the inside. but i cnt get to that anyway can i.
from big forum
Clean Headlights.
Postby Mr Morlock » Sat Oct 25, 2008 12:26 pm
Gents trust me- this is just a case of applying a light polish to a cloth rub on and rub off- apply again if not satisfied- but do not rip it into it- you do not want to completely remove the unseen hard coating on the lenses which provide long term life. I recently did this on badly weathered headlamp lenses on a Festy and the job was done in 5 minutes. It is the same process as polishing your paintwork. As an aside I have often seen taillight lenses buffed to remove marks in OE manufacture and it recovers otherwise reject parts. Too easy they say.
irwin83r
Clean Headlights.
Postby irwin83r » Sat Oct 25, 2008 1:27 pm
here. before and after shots using mothers plastic on the out side only. pretty good results considering i done a very half assed job. if you shake the bottle well do it in the shade when the surface is cool and apply loads of elbow grease aswell as doing it two or three times in the one sitting you should end up with even better results.
if you can avoid taking the lenses off avoid it. condensation on the inside of your lights looks terrible and isnt easy to get rid of. but if you have to polish the inside (i cant see why) then you'll have to... just be carefull and make sure you get a really good seal when putting it all back together.
yes my car needs a bath... badly :oops:
Clean Headlights.
Postby Mr Morlock » Sat Oct 25, 2008 8:26 pm
The weathering on your lenses occurs on the outside not the inside. Your lens are hot melt glued into a glue track and they are leak tested at the manufacturing point. If you heat and remove the lens you seriously run the risk of no longer having a leak free glue track- the headlamps were never designed to be serviced ( apart from bulb replacement) and that is why you cannot buy a lense separately. If a headlamp has excessive moisture in it this may be because of some damage or deterioration to the glue track or as with most headlamps a breather is blocked- lamps breathe they are not simply fully sealed as the air inside when heated expands and contracts when it cools thus it can suck in some moisture. The sun usually sorts out moisture fairly quickly. Incidentally you cannot buy the engineering hot melt that the manufacturer originally used which is a product that has a tight spec. Lenses are treated in principle like plastic lenses in spectacles- they are coated for durability and removing that coating or scratching it excessively shortens the life. Polish rejuvenates plastics and paint- restoring gloss but you do not use a heavy polish on old thin paint and the same with the lenses.
wun911
Clean Headlights.
Postby wun911 » Sat Oct 25, 2008 9:56 pm
tooth paste...
every ounce counts
