Hi all
I want to change the gear knob on my NC. I understand the old one just screws off.
Can anybody give suggestions as to the best way of getting the old one off without damaging it.
I am sure a large set of multigrips work but.......
NC gear knob removal
- Penguin
- AJ
it should just screw off easily, unless someone ham fisted oaf has tightened it tighter than you can unscrew it, mine came off easily.............I would suggest multigrips, but wrap the knob with a rag to protect it, & just lean on it gently & by degrees until it gives............
XMX5 Rogues
- JBT
- Penguin
When I get home I will have to put all my brute (?) strength into it. No multigrips.
- bruce
- Vehicle: NA8 - Turbo
- ampz
- Vehicle: NA6 - Turbo
Try wrapping a leather belt around it a couple of times then pull, it will be easier to grab with your bill
Huh?
- Penguin
After a lot of flapping and using my web feet I got the knob off.
New knob feels mucj better in my hand.
Thanks for the help.
Penguin wrote:New knob feels mucj better in my hand.
Any chance you want to sell your original gear knob?
