Removing seal on door under window ???????
emexv
Postby emexv » Sat Sep 20, 2008 1:06 pm
I've had a hunt around but can't seem to find the info I'm after. I nned to remove the rubber trim on the outside of the door under the drivers side window to do a minor repair. I don't want to wreck all the clips etc trying to do this. Also does the quarter window have to come out first?
Can someone please give me a few pointers on the procedure to get this seal off.
Thanks in davance
Mark
Alex
Postby Alex » Sun Sep 21, 2008 2:56 am
I remember Babs (who has since moved on) had a thread around here somewhere showing removal and replacement of this on an NA
Edit: Found it
viewtopic.php?f=28&t=28153
TieNN89
Postby TieNN89 » Sun Sep 21, 2008 12:40 pm
emexv wrote:I've had a hunt around but can't seem to find the info I'm after. I nned to remove the rubber trim on the outside of the door under the drivers side window to do a minor repair. I don't want to wreck all the clips etc trying to do this. Also does the quarter window have to come out first?
Thanks in davance
if your gona remove it buy a new one to replace it
its not easy to remove
once the strip is bent good luck making it sit back nice and neat
there approx $60 each at the spare parts counter :)
