Sparco Sprint JNR q's
Posted: Sun Aug 24, 2008 5:00 pm
by RG.net
i sat in my mates sparco sprint today and i fell in love, much tighter then the monacos i have now and it lets me sit lower in the car. we test fitted them in my car today to see where they would sit with the rollbar, suprisingly they sit further back then my monaco's so they will be up for sale when i get some sprint jnr's.
i am curious on a few things though.
my mate says that they are a straight fit, however he has a na6 and the rails holes dont line up to my 5. so are these seats a straight fit for nb's? if not, what work needs to be done to get these jems to fit?
also who distributes these seats?
Posted: Sun Aug 24, 2008 7:33 pm
by sliq
yup, last time i checked they are a straight fit.. you can use your existing rails with minor modifications.
the sparco sprint junior line finished a year or two back.. they come up sometimes on ebay...
Posted: Sun Aug 24, 2008 8:01 pm
by MXcrazy
I've got Sparco Sprint V's in My Nb8a, and with a few minor modifications, they will fit perfectly on the standard seat rails.
However, the passenger side installation is much more difficult than the driver side installation, with more extensive modifications required to achieve the same fit...
Peninsula sports car services in Brookvale may have the older Sprint Jnr Seats, so give them a buzz.
Posted: Sun Aug 24, 2008 8:27 pm
by RG.net
what i am curious on is what the minor mods are?
Posted: Mon Aug 25, 2008 8:41 am
by sliq
drilling bigger holes into the rails. something of that nature.
Posted: Mon Aug 25, 2008 11:38 am
by philz
Alex did a review and installation with pictures.
But with the new updates on the forum I can't seem to get into the Installation link.
It shows a detailed process of what to do.
viewtopic.php?f=28&t=29600
Posted: Mon Aug 25, 2008 7:42 pm
by Alex
here is the link with lots of photo's
but here are 2 photo's of the drivers side rails,
normal on top, modified on bottom
look up the spacing for the sprint jr mounts and compare to the sprint V
Posted: Wed Aug 27, 2008 8:26 pm
by RG.net
doesnt look like much, just open up the hole with a drill
thanks alex, i contacted sparco today, they say the sprint V is the replacement of the jnr, i'll be chasing a pair up soon me thinks
Posted: Fri Sep 05, 2008 10:16 pm
by sabretooth
I just put an extra hole in the rail. Easy to do - otherwise it's a bolt-in job.
Posted: Fri Oct 24, 2008 4:19 pm
by irwin83r
dont go over bored enlarging holes... you will make them weaker and if you go over bored the rails wont slide over the bolt heads in the slider. i did what sabretooth suggests and drill new holes.
the passenger side one isnt as smooth a modificatoin... you really need to do the extra holes and then slot the holes that hold the rails to the floor.. and then the bolt heads of the bolts that hold the rails to the floor foul on the recess that are pressed into the rail from factory and worse still on the nb8as theres a dowl or locating pin that goes into the floor pan that you will have to remove.... it was ages ago that i put mine in though so you might be able to just slot (enlarge the holes in one direction) and then man handle the seat in.
i ended up making in an adaptor plate to offset the rail on the passenger side out of some steel plate.
Posted: Wed Dec 10, 2008 12:50 pm
by timk
I measured, center punched and drilled the rails in the SE last night all without issue.
The problem I've got now is that the Sparco Sprint V has side mounts as well as bottom mounts, and these additional side mounting points are fouling on the OEM bolt spacers welded to the vertical seatbelt plate on the LHS rail (my NA didn't have this plate as the seatbelt was mounted on the transmission tunnel). Did you guys just mill/grind the two spacers off?
Posted: Thu Dec 11, 2008 12:03 am
by Alex
saboteur wrote:The problem I've got now is that the Sparco Sprint V has side mounts as well as bottom mounts, and these additional side mounting points are fouling on the OEM bolt spacers welded to the vertical seatbelt plate on the LHS rail (my NA didn't have this plate as the seatbelt was mounted on the transmission tunnel). Did you guys just mill/grind the two spacers off?
Yep this is a problem with the sprint V's
see my thread regarding modification of the rails, ended up having to grind them down a bit
Posted: Mon Dec 22, 2008 12:09 pm
by NMX516
saboteur wrote:I measured, center punched and drilled the rails in the SE last night all without issue.
The previous Sprint had the same problem for me with the NB rails, so I solved that problem with the angle grinder. If you're still in the process of doing this and need a grinder let me know.
Posted: Tue Dec 23, 2008 1:24 am
by timk
NMX516 wrote:The previous Sprint had the same problem for me with the NB rails, so I solved that problem with the angle grinder. If you're still in the process of doing this and need a grinder let me know.
Thanks for the offer Gerard!
Fortunately I just borrowed my dad's grinder and got to work with the help of my mate Luke, here are the results:
I have another headache now though, the rails seem to sit about 10mm too close together so I can't put the seat into the car!!!
For the record the holes I drilled in the back of the OEM rails are perfectly in line with the original holes and are the same size. Do you think maybe the seat could be out?
I did the same mod in my NA and never had a problem like this!
