Is there a trick to removing the Frankenstein bolts?
Posted: Sat Aug 02, 2008 11:57 am
by Fatty
just use a big flat head screwdriver to unscrew them
Posted: Sat Aug 02, 2008 7:23 pm
by Tezzax5
Michelle don't wreak your baby over these bolts...
If you can't get them out i'll just source some others...
I had a look at google images and they should be just like a big screw but who knows how they were put in originally..
Like i said if you get them out great if not.....No Problem it ain't the end of the world..
regards
Terry S
Posted: Sun Aug 03, 2008 1:32 am
by Alex
I've heard of the anchoring thread breaking off before, that might be what has happened
Posted: Sun Aug 03, 2008 10:11 am
by TieNN89
TheMissus wrote:I've tried using a big screw driver to remove them and the bolts keep spinning like the nut underneath is turning with it. I can't figure out where to get at the nut to hold it still so the bold unscrews.
o dear
sounds like the cage nut has ripped off
is it still fairly firm to turn
Posted: Sun Aug 03, 2008 10:45 am
by Mr_Q
TheMissus wrote:... It is probably only slightly tricky but for the life of me I can't figure it out
I'm pretty sure the trick is to leave them on the car and buy a new pair for the other car.
It is
possible to remove them, but you seem to have a better chance of breaking them. A new pair is under $50, which is expensive for bolts, but not too bad as part of a new hardtop price.
Posted: Fri Aug 08, 2008 9:16 pm
by trader
The nut on the other end of the bolt is obviously turning. Fiddly to get at - you need an open end spanner - a torch and mirror inside the boot will show you the problem. You have to take off the panel inside the boot to get to the left hand side one. From memory it is not much fun replacing them. I glued the nut in position then tightened the bolt.
Posted: Sat Aug 09, 2008 12:12 am
by TieNN89
TheMissus wrote:AZNTieN wrote:is it still fairly firm to turn
Sure is ... that's a bad thing I am assuming?
no not really as long as its still firm - tight
leave it alone and get another set for the other car lol
Posted: Fri Sep 05, 2008 11:13 pm
by muzza2
there is actually a tool you can buy to fix this problem
its a screw driver that when you bash it with a hammer on the top end it will actually "crack" stuck bolts
(obviously) in this case u'll have to be very careful, but it kinda works the same way as a rattle gun
once hit, it moves the bottom piece about 30% in a rotation direction very quickly. (like a quick jab)
this may loosen the bolt to then use a normal screw-driver to undo the bolt.
Posted: Fri Sep 05, 2008 11:25 pm
by orx626
muzza2 wrote:there is actually a tool you can buy to fix this problem
That would be an "Impact driver" Muzza.
Posted: Sat Sep 06, 2008 12:07 am
by TieNN89
and what every you do do not miss otherwise you could hit your precious instead
Posted: Sat Sep 06, 2008 10:05 am
by muzza2
orx626 wrote:muzza2 wrote:there is actually a tool you can buy to fix this problem
hahah, it was around 12am, i was tired and i couldnt think
BUT! yes thats exactly what i was talking about!
Posted: Sat Sep 06, 2008 11:12 pm
by DC1200
There is a fair chance the bolts have some sort of locking agent ( Loctite thread locker, etc) on them from the factory. You could try to
carefully heat the bolts with a heat gun, or a hairdryer first before using the screwdriver or impact driver (don't flog the impact driver too hard or you may damage the panel surrounding the area). Make sure you use the correct size screwdriver, No3, not the common No2 size, to avoid damaging the bolt itself. Good luck, hope this helps.
Posted: Sun Sep 07, 2008 12:25 am
by TieNN89
why do you want to remove these bolts anyway?
Posted: Sun Sep 07, 2008 12:32 am
by Mr_Q
AZNTieN wrote:why do you want to remove these bolts anyway?
Are you kidding? They must weigh heaps!
(or maybe they just want to move them to another car
Posted: Sun Sep 07, 2008 9:32 am
by Tezzax5
I bought a hardtop from derek and michelle and we were going to use the bolts on my car but i have since sourced some others so the missus didn't have to wreck her car.....
