Tightening hardtop at frankenstien bolts
Postby Okibi » Thu Jul 10, 2008 10:02 pm
Theres a philips head screw on the metalic bits at the back of your hardtop. Look on the inside edge of both (i think) take that screw out, the top part of the metalic piece will pivot across, then you can adjust the 2 bots that hold the C shaped part that grips the Frankenstein bolts.
It will make more sense when you do it. :lol:
Garry
Postby Garry » Fri Jul 11, 2008 9:51 am
There is a plastic coating on the adjusting shims that may have worn through. If it has you can flip the shim over and use the other side. You might also want to check where the soft top latch rests against the stoppers on the hardtop. My car squeaks from there really badly. I use 2 little pieces of cardboard between the latch and the stopper to stop the squeaks.
