DONT REMOVE LATCHES
Posted: Sat Jun 14, 2008 6:17 pm
hey guys just writing to explain my day,
ive been drilling out the bolts which hold the 2 latches in my hardtop above my head. a few months ago i had a great idea to swap the latches over with a spare set which were in better condition than the ones on my hardtop.
the passenger side came off relatively easy, few grunts and groans but i got them undone to find they had been soaked in locktite before being put in, from mazda factory i assume. i got to the drivers side got it about 1 and half full turns and became quite hard to turn. i then managed to strip the philips head off 2 of the screws. which is allways embarrassing. when explaining a problem but its done. so now i have 2 bolts which i cant loosen or tighten they are about 1mm from being tight against the latch.
i drove it and it rattled like sh*t. so i managed to squeeze a piece of plastic in there to stop the vibration which worked for a while but it came loose and fell out after going over a few small bumps in the road. koni yellows dont help either.
so today i got a screw/bolt remover which has a small drill bit and a funny tapered looking drill bit which you use after drilling a small hole in the bolt and it pulls it out. i broke both bolts doing this. but eventually managed to get it to work. i didnt destroy the thread!!! and i have now the new latch fitted when if i had have known i would have just left them. as they were fine.
DONT CHANGE THEM!
unless you need to of course.
DONT CHANGE THEM!
