Page 1 of 2
Negative bling
Posted: Thu Apr 17, 2008 8:47 pm
by Andrew
Posted: Thu Apr 17, 2008 8:57 pm
by AB7
Looks good, I saw this like 2 months a go on some US website. I think its cheaper too, around $120
Posted: Thu Apr 17, 2008 9:59 pm
by Alex
yea I actually like the look of it
Posted: Thu Apr 17, 2008 11:09 pm
by TieNN89
but its only for the nas
Posted: Thu Apr 17, 2008 11:26 pm
by stevesports
couldn't you just buy the chrome one and then spray paint it black?
Posted: Fri Apr 18, 2008 3:20 pm
by wun911
oh man I thought it was CF...
Posted: Fri Apr 18, 2008 4:03 pm
by AB7
wun911 wrote:oh man I thought it was CF...
Look in Ebay US, saw one not long ago. Guaranteed so shave 0.000001 sec of you acceleration time.
Posted: Fri Apr 18, 2008 4:12 pm
by wun911
Black paint (added weight)
And CF looks better
Posted: Fri Apr 18, 2008 8:50 pm
by sliq
imo i think cf doesn't match every colour of the 5.. certainly wouldn't look very schmick with my supreme blue
Posted: Tue Jul 22, 2008 12:20 pm
by rain902
and andrew has jsut seen it on the back of my NA - a nice replacement for the broken spring on the original
Negative bling
Posted: Thu Jul 31, 2008 2:16 pm
by CheyneX5
i like the cf
Negative bling
Posted: Thu Jul 31, 2008 6:22 pm
by Mr Morlock
The link to me simply looks like a black plastic injection moulding with pressed metal bracketry attached. The supplier should readily be able to tell you what is the material. The suggestion about painting chrome is to be avoided. It is very hard to get good adhesion and durability as the surface is so smooth. Even chrome plating of plastic is a challenging process - achieved with plating grade plastics and very carefully controlled mouldings to avoid stress. Apart from appearance I could not really see any purpose in a CF construction for a petrol cap.
Negative bling
Posted: Thu Jul 31, 2008 6:59 pm
by rain902
Mr Morlock wrote:The link to me simply looks like a black plastic injection moulding with pressed metal bracketry attached. The supplier should readily be able to tell you what is the material. The suggestion about painting chrome is to be avoided. It is very hard to get good adhesion and durability as the surface is so smooth. Even chrome plating of plastic is a challenging process - achieved with plating grade plastics and very carefully controlled mouldings to avoid stress. Apart from appearance I could not really see any purpose in a CF construction for a petrol cap.
which link? the UK one is not injection moulded plastic with pressed metal bracket attached, you can examine it this sunday if you wish to...
Negative bling
Posted: Thu Jul 31, 2008 7:29 pm
by Mr Morlock
It certainly looks like it to me. 2 mouldings ring and lid and bracket(s)probably hinged with a roll pin and spring and mounting screws. If it is not plastic it merely demonstrates that the picture and description are inadequate.
Negative bling
Posted: Thu Jul 31, 2008 8:11 pm
by meanmx
Mr Morlock wrote:It certainly looks like it to me. 2 mouldings ring and lid and bracket(s)probably hinged with a roll pin and spring and mounting screws. If it is not plastic it merely demonstrates that the picture and description are inadequate.
Looks like metal to me
Ben
