Page 1 of 2
Posted: Fri Mar 28, 2008 11:25 pm
by Locutus
bottom one should fit since it's a momo.
top one won't as it's nardi, and will probably be expensive buying one with an intact airbag centre.
Posted: Sat Mar 29, 2008 11:51 pm
by Locutus
pretty sure it bolts right up.
as far as i know momo bosses all have the same 6 bolt pattern.
Re: Factory NA8 or NB Steering wheels into NA6?
Posted: Sun Mar 30, 2008 12:30 am
by orx626
li21 wrote:
(This is orx626's car interior - nice car btw!!)
Cheers mate. For your information...this particular Momo wheel has an integrated boss ie. the wheel and boss are one unit and cannot be separated. The interior is from a 1996 NA - VR Ltd B spec (JDM).
As far as the steering shaft spline is concerned, from NA through to NC they are all the same. However, how the various steering wheels interact with the various column surrounds and indicator/light stalks/airbag units; I wouldn't be surprised if there were some conflicts between models.
Regards,
Posted: Sun Mar 30, 2008 1:51 pm
by orx626
li21 wrote:That woul dmean I could put an NB steering wheel on an NA.. so long as I dont expect the airbag and controls to work...
Yes and you are correct, the air-bag won't work unless you have everything else that goes with it.
li21 wrote:And Im guessing there should be no problem fitting your wheel (NA8 Momo) to my NA6? But issue is finding one!
Yes, definitely no problem fitting the NA8 wheel on an NA6. Yeah there's not too many of them floating around. Have seen them on ebay only a few times in the past 3 years.
Regards,
Posted: Sun Mar 30, 2008 9:34 pm
by Boyracer
1.Forget about fitting the NB wheel...not worth putting on a air bag...will cost you a fortune...I could sell you a steering wheel but it goes with the 2 Air bags...would cost you $1500. minimum.
2.As stated the late model NA Momo wheel has the boss as part of the steering wheel...but it does fit any model NA or NB.
Posted: Mon Mar 31, 2008 7:32 am
by Boyracer
You can use the deployed air bag but would have to get it recovered as it rips open...not sure if it would look very good.
Posted: Thu Apr 03, 2008 2:39 pm
by sabretooth
By the way, this is what an Aust-delivered NA8 wheel looks like:
As Danny said the particular wheel you've linked is JDM.
Posted: Thu Apr 03, 2008 3:12 pm
by Boyracer
The Momo wheel in the photo is the one fitted to the later model NA8s in Australia.
Posted: Thu Apr 03, 2008 5:52 pm
by sabretooth
Ahh yes for the airbag, correct?
Posted: Thu Apr 03, 2008 7:40 pm
by Locutus
nope. i have that wheel. no airbag.
Posted: Fri Apr 04, 2008 10:53 am
by pcmx5
The wheel shown in orx626's car is the same as in my Aus. delivered 96 LE- no airbag.
It is hard to get off,when I took it for an alignment they could get it off to re-centre the steering wheel, had to compensate under the car.
Has anyone taken one off?
Peter
Posted: Fri Apr 04, 2008 4:47 pm
by orx626
pcmx5 wrote:Has anyone taken one off?
Peter
Yes. No problem. Removed the centre nut, banged around the rim of the wheel and then applied alternating force to the rim as I pulled it towards me without hitting myself when the spline/taper lock released.
Regards,
Posted: Tue Apr 08, 2008 9:08 am
by pcmx5
Thanks, Danny.
peter
Posted: Fri Feb 27, 2009 4:16 pm
by bruce
Looks like a WRX wheel. Looks like it has an integrated boss for the Suby (like ORXs - integrated boss for the 5). I think that's a no go.
Posted: Tue Mar 03, 2009 3:55 pm
by bruce
Looks like another integrated hub (if the hub is for a 5, fine). You need a wheel which has basically nothing attached (then fit the correct hub).
