Fitting other Steering wheels into NA6?
- Locutus
- Locutus
- orx626
- Vehicle: NC - Rotary
Re: Factory NA8 or NB Steering wheels into NA6?
li21 wrote:
(This is orx626's car interior - nice car btw!!)
Cheers mate. For your information...this particular Momo wheel has an integrated boss ie. the wheel and boss are one unit and cannot be separated. The interior is from a 1996 NA - VR Ltd B spec (JDM).
As far as the steering shaft spline is concerned, from NA through to NC they are all the same. However, how the various steering wheels interact with the various column surrounds and indicator/light stalks/airbag units; I wouldn't be surprised if there were some conflicts between models.
Regards,
- orx626
li21 wrote:That woul dmean I could put an NB steering wheel on an NA.. so long as I dont expect the airbag and controls to work...
Yes and you are correct, the air-bag won't work unless you have everything else that goes with it.
li21 wrote:And Im guessing there should be no problem fitting your wheel (NA8 Momo) to my NA6? But issue is finding one!
Yes, definitely no problem fitting the NA8 wheel on an NA6. Yeah there's not too many of them floating around. Have seen them on ebay only a few times in the past 3 years.
Regards,
- Boyracer
- MX-5 Encyclopedia
1.Forget about fitting the NB wheel...not worth putting on a air bag...will cost you a fortune...I could sell you a steering wheel but it goes with the 2 Air bags...would cost you $1500. minimum.
2.As stated the late model NA Momo wheel has the boss as part of the steering wheel...but it does fit any model NA or NB.
- Boyracer
- MX-5 Encyclopedia
- sabretooth
- Vehicle: NA8 - Turbo
- Boyracer
- MX-5 Encyclopedia
- sabretooth
- Locutus
- pcmx5
- Vehicle: ND - 2
The wheel shown in orx626's car is the same as in my Aus. delivered 96 LE- no airbag.
It is hard to get off,when I took it for an alignment they could get it off to re-centre the steering wheel, had to compensate under the car.
Has anyone taken one off?
Peter
Peter
- orx626
- pcmx5
- Vehicle: ND - 2
- bruce
Looks like a WRX wheel. Looks like it has an integrated boss for the Suby (like ORXs - integrated boss for the 5). I think that's a no go.
- bruce
Looks like another integrated hub (if the hub is for a 5, fine). You need a wheel which has basically nothing attached (then fit the correct hub).
